Wireless Transmission System for PMW-EX1 at DVinfo.net
Old July 2nd, 2008, 10:49 PM   #1
so far, in order to get that 422 color space some favors, it mostly requires a hard wired connection with a computer loaded with one of several black magic capture cards from the PMW-EX1 hd-sdi to the black magic card in a mac pro desktop.
if you want to use the macbook pro, then you'll need to get the aja iohd that sits between the ex1 and the mbp.
the top is the cheapest method and the aja cost over $3000
now, i understand there is a wireless solution where you can use any mac, desktop or mbp.
it's the CW-5HD from IDX.
http://www.idxtek.com/products/trans_sys.html
at a cost of around $6000 and you'll get full 422 and almost live broadcast functionality.
anyone already seen this work?
paul
Paul Chiu is offline   Reply With Quote
Old July 3rd, 2008, 06:33 AM   #2
Images: 1
that freaks me out. I'd probably wear a bullet proof body suit. I just don't want 4.2.2 color space running through my body.
Benjamin Eckstein is offline   Reply With Quote
Old July 3rd, 2008, 06:42 AM   #3
yes ben,
that is a big concern for me as well.
i'd definitely find a shop with one on display and bring a trifield meter to test for unsafe levels of magnetic and microwave energy.
paul
Old July 3rd, 2008, 07:45 AM   #4
Now that is something I could use from time to time. Unfortunately at that price I would have to need it a lot more often than I do.
Crossing my fingers other more affordable options could be lurking around the corner.
http://www.LandYachtMedia.com
Old July 3rd, 2008, 09:35 AM   #5
This is just a wireless transmission unit. It's nothing like the Aja Io, Matrox MXO2, MOTU V4HD units or Blackmagic or AJA cards that are all capture devices to be used with a computer.
The IDX will just transmit the SDI signal a few feet away. Good for a directors monitor when you're doing a steadicam shot or maybe even to hook it up to a capture device (or both). It just replaces the coax cable.
Want a stand alone tapeless field recorder that does 4:2:2 Full Raster 10-bit from HD SDI in visually lossless quality and produces files you can edit on both Mac's and PC's? Take a look at the Wafian HR-F1 Field Recorder.
Or you can go for the Flash XDR for 4:2:2 Full Raster 8-bit in a few MPEG2 flavors. An uncompressed option has been announced as well, although you will still need to capture it to ingest so practically you'll need two devices and/or a lot more cards.
George/
George Kroonder is offline   Reply
