xdcam default clip name at DVinfo.net
Old June 26th, 2008, 03:11 PM   #1
We are using one of the earlier versions of the XCAM EX1. When we bring in the clips using xdcam transfer I notice that the clips have a “_01” added to it. Is there any way to get rid of the “_01” with out having to give the clip a new name?
I notice that in the pdf, that comes with xdcam transfer under help (version 2.7.0) they don’t show a “_01” under the logging/clip section. Could it be as simple as updating firmware in the camera?
Any help will be more than appreciated.
Marta Martinez is offline   Reply With Quote
Old June 26th, 2008, 07:17 PM   #2
My clips get a _01 added to them when I try to import them more than once. I believe this is to protect you from overwriting clips with the same name. There is a setting in the XDCAM transfer software to turn this off.
Kevin Walsh is offline   Reply With Quote
Old June 27th, 2008, 06:28 AM   #3
I believe the clips are named this way to make merging of sequenced clips possible. If you make a long recording that spanns two cards the first part will have _1 at the end and the second _2 etc. When they are later merged together using clipbrowser the merged clip does not have anything added to the end.
In short - all short clips end with a _1 and merged clips don't have this ending.
Ola Christoffersson is offline   Reply With Quote
Old June 28th, 2008, 05:44 AM   #4
XDCAM Transfer Preferences Import tab Filename - For subclips add index number. Uncheck to get rid of _1.
Craig Seeman is offline   Reply
