EX3 style viewfinder eyepiece for EX1 - Page 2 at DVinfo.net
Old June 27th, 2008, 09:19 AM   #16
Good point Serena I will try the eye cup from the view finder to see how that works.
Paul Cronin
www.paulcroninstudios.com
Old June 27th, 2008, 04:09 PM   #17
I took my M3 viewfinder to the optician shop,. They measure the plastic lens, and it is a +8 Diopter, Does any one have a source of a diopter supplier?
Regards
Steve
Steve Cahill is offline   Reply With Quote
Old June 27th, 2008, 05:42 PM   #18
Steve,
What do you think about the view through the M3 lens? With it installed in my LCD hood it seems very good, but I'd like to see a slightly less magnified image. I find myself peering around the corner a bit to see the corners of the screen.
What's your take?
M.
Michael Belanger is offline   Reply With Quote
Old June 27th, 2008, 07:45 PM   #19
Lense for hoody viewfinder
I found something that seems to work.
http://www.bhphotovideo.com/c/produc...ier_Model.html
I took this magnifier apart and mounted the lens into some soft foam that I fit into my Hoodman H400. Seems to work in the studio at night. I will test it out in the daylight tomorrow.
Charles Dasher is offline   Reply With Quote
Old June 27th, 2008, 09:02 PM   #20
A scuba dive shop, they have diopter inserts for dive mask's...
Old June 28th, 2008, 01:02 AM   #21
Images: 3
Usually any optician can supply spectacle lenses, with which you make an eyepiece. Not as good as one specifically designed, but very usable if you don't try to go for too great a magnification; not more than 7 or 8 diopter (a focal length of 140 to 125 mm). More powerful than that and a simple arrangement won't cover the required field.
Old June 28th, 2008, 05:03 AM   #22
I have not tried the magnifier, as of yet just found the M3 eyepiece, I will mount it and check it out.
Regards
Steve
Old June 28th, 2008, 10:37 AM   #23
Thanks Steve. Mine is at the farthest distance from the LCD that's still in focus, which happens to coincide with my lcd hood nicely.
M.
Old June 28th, 2008, 04:11 PM   #24
What I find with any sort of hood is that you have to keep taking it off when your on the move to safely store the LCD, need a quick solution to attach and unattach.
Regards
Steve
Old June 28th, 2008, 06:03 PM   #25
Images: 3
Well, the fastening you see here meets that criterion (an elastic hair band hooks around and upper and lower knob). But the hood is just a "boiler plate" test prototype.
http://www.dvinfo.net/gallery/showim...mageuser=28517
Old June 28th, 2008, 08:21 PM   #26
Hey Michael are you going to post the "how to" for the viewfinder and the shoulder pad
Robert Musiello is offline   Reply With Quote
Old June 29th, 2008, 08:58 AM   #27
I was visiting with a third party developer who is looking into such a product. Really cannot discuss obviously, but already working on the concept.
Ned Soltz is offline   Reply
