Balancing an EX1 on a sachtler DV 6 SB - Page 2 at DVinfo.net
Old June 3rd, 2008, 12:19 PM   #16
lenny,
i did not play with the miller #1022, that's the arrow 25 as i did with the ds-20 as i had no need for that much weight for my EX1 setup. that said, for a $2500 head, the arrow 25 has what i like with "number" dials for counterbalance and separate pan and tilt number settings. extremely precise and i would go there if i had more than 20 lbs of setup weight over the sachtler dv8
i am not sure though with your 35mm and a monitor with EX1, your setup is below the weight level of the arrow 25. it does look big and solid enough for the F350 and larger!
paul
Paul, I've been trying to find someone who has compared a DS-20 with an Arrow 25. Any thoughts?
I am thinking about it with a 35mm and zoom lens + a monitor so the weight is more than the Ex-1 alone.
Lenny
Paul Chiu is offline   Reply
