Rendering time with EX1 HQ footage? - Page 2 at DVinfo.net
Old May 18th, 2008, 06:41 AM   #16
Originally Posted by Jonathan Bland View Post
What I need is a thread where Barry and Craig punch it out on techniques :)
Sorry Jonathan, I'm to mild mannered and besides its Sunday :-))
About the only other suggestion, I can offer is that if I'm going to use a ProRes timeline, then I transcode my footage to ProRes up front and then edit. This has been reliable on my system. But then as mentioned above, I do not have any of those plug-ins installed.
Barry J. Anwender is offline   Reply With Quote
Old May 18th, 2008, 07:15 AM   #17
Originally Posted by Daniel Weber View Post
He said he was editing on a Mac Pro using Final Cut, why would he edit in AVI?
Daniel Weber
Yes, sorry... don't edit in AVI, use Cineform and edit in MOV.. still faster
Old May 18th, 2008, 11:30 AM   #18
Originally Posted by Josh Dahlberg View Post
I also use Noise Industries plugins on my constantly crashing Mac Pro. The crashes only happen when I render in ProRes.
My 24" Imac with the same plugins does not crash.
Thanks for your detailed info David.
Somehow, only Apple can answer and solve these.
David Cheok is offline   Reply With Quote
Old May 18th, 2008, 04:47 PM   #19
Thanks Barry, I just tried a complex 20 minute render - ProRes material in a ProRes timeline - with Noise Industries & Magic Bullet plugins and it worked without a hitch.
It's a pity the other method doesn't work for everyone (ie: keeping the material HDV and rendering ProRes) as it requires less storage up front and no transcoding.
At any rate I appreciate your suggestion. Looks like I'll follow your route.
Josh
Josh Dahlberg is offline   Reply With Quote
Old May 30th, 2008, 11:25 AM   #20
any difference in the rendered video or speed in rendering if you pick "Best" for quality?
Originally Posted by Craig Seeman View Post
FCP XDCAM HD/EX & HDV settings to render Pro Res to avoid GOP re-conform
Paul Chiu is offline   Reply With Quote
Old May 30th, 2008, 11:51 AM   #21
pro res
is the pro res codec only for mac's with intel processors? or will my dual g5 also accept prores?
Jurgen Taghon is offline   Reply With Quote
Old May 30th, 2008, 12:07 PM   #22
I can confirm that ProRes also works on the G5. I have a G5 Quad as well as the MacPro Octo.
I just updated to Leopard 10.5.3 yesterday. Some folks as mentioned above are having problems with ProRes in FCP. While ProRes works fine on my FCP configuration, I was having stability problems in Compressor when using all 8-cores. I will be testing in the next week to see if 10.5.3 has corrected this. Cheers!
Old May 30th, 2008, 12:08 PM   #23
Hola Jurgen,
Capturing HD resolution video using the ProRes 422 format requires a Mac Pro with Intel Xeon processors or a Power Mac G5 Quad 2.5 Ghz, and a qualified third-party capture card.
Ivan Snoeckx is offline   Reply With Quote
Old May 30th, 2008, 12:11 PM   #24
thank you, i will try it later today.
I have a G5 dual 2.5.
