Best for low light.
Quick question,which is best for low light on an EX1? Interlaced or progressive ?
Thanks. Paul.
Round 2 GH5,FZ2000 |
Quick, but difficult one...
Due to the line-doubling effect, the EX1's sensitivity in interlaced is reported to be double that of progressive (800 vs 400 ASA). However, you can effectively make for it by switching shutter off, which is only really viable in progressive... I use the latter option exclusively.
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
Would the better light sensitivity in interlaced affect the dof?
How on earth? Because it'd make you close the iris? Well - use ND filters! Or even faster shutter, if DOF is your priotity.
#5 |
#6 |
Yes - the effect you mean I mentioned above.
#7 |
#8 |
At a given focal length, only the iris affects DOF. Chip sensitivity (gain, interlacing etc.) will have no effect on DOF unless you stop down to compensate.
But as Piotr said, there are ways other than stopping down the iris to compensate for exposure - such as ND filters (the best solution) and shutter. Using these methods will have no effect on DOF. |
#9 | |
#10 |
With interlacing the extra stop has nothing to do with the optical path. The chip has twice as many photons to work with on a given field (half the resolution) and hence is twice as bright.
#11 |
Thanks Eric; I tried to explain the exactly same thing to Mark, but apparently my English is not good enough :)
#12 |
Interlaced is better in low light then,thanks guys.
Paul.
#13 | |
Paul,
I refer you back to Piotr's response - you are not really getting something for nothing... Quote:
#14 |
#15 | |
Perhaps my answer should have been worded like this (bolds added): "Due to the line-doubling effect, the EX1's sensitivity in interlaced is reported to be double that of progressive (800 vs 400 ASA). However, you can effectively make for it by switching shutter off, thus gaining one stop, which is only really viable in progressive as you don't get the motion blur you would get in interlaced..." Is it more clear now?
