Help, SDI-Out with BNC not working on flyer! at DVinfo.net
Old April 4th, 2008, 02:29 PM   #1
We are about to leave for a wedding.. and..
The SDI-Out with a BNC cable out into the BNC in on monitor on the flyer and we are getting no signal... It doesn't matter if it's set to SD or HD on the camera..
Any suggestions?
John Edgar is offline   Reply With Quote
Old April 4th, 2008, 02:38 PM   #2
Hi John
Check under the 'Others' menu that I-Link I/O is set to disable. If this is enabled, it disables SDI.
Cheers,
Nick
Nick Wilson is offline   Reply With Quote
Old April 4th, 2008, 04:02 PM   #3
The standard flyer monitor is composite only.
Charles Hurley is offline   Reply With Quote
Old April 4th, 2008, 06:34 PM   #4
So there is no way to get the SDI out port to work with the standard flyer monitor? We would then need to find another output on the camera?
Nick, When we turned it off, we got snow for a second and then back to No Signal.
Old April 4th, 2008, 09:10 PM   #5
The standard Flyer monitor does not accept an SDI signal. You have to use the composite output cable on your EX1, and plug a RCA to BNC adapter to hook it into your sled's BNC connector.
Mark Britton is offline   Reply
