Thread Tools
Search this Thread
#16 | |
Hard Drives: Many of the USB or Firewire Hard Drives make a great backup solution. HOWEVER, hard drive do fail and if one does, there goes all your video. The smart move is to have a second or even third copy of your videos on a second (or third) drive. That way if one drive fails, you have a second copy on another drive. The third drive provides that extra bit of protection, in the unlikely event that 2 drives fail. This system does require that once or twice a year, you run a hard drive check to make sure the drive didn't freeze up or die. The expected life of hard drives is around 3 to 7 years. So, in time you will need to replace defective drives, but by then drives will be larger and cost less. I would STRONGLY suggest that you have the drives be from different manufacturers. That way, if a manufacturing defect does occur, it only kills one of your drives. As for which brands, every time I recommend a brand someone else always says, "It's junk.." However, I've had good luck with Maxtor, Seagate, and Western Digital. I've also heard good things about LaCie. Figure that the EX-1 is generating ABOUT 16GB per hour. (This is a bit off, but close enough for estimates.) A 1TB drive should hold over 60 hours of video. Given that 1TB USB drives now sell for under $300, that comes to less than $5 per hour per drive. Optical, DVD: Both 4.7 GB (SL) and 8.5GB (DL) DVDs are possible, but that is going to take 2 (DL) to 4 (SL) DVDs per hour of material. Like the hard drives, ALWAYS HAVE A SECOND COPY!!!!! Now we are looking at 4 (DL) to 8 (SL) DVDs per hour. Like the hard drives, I would always copy to different brands, to avoid the risk of a manufacturing defect that kills the disk later on. For brands, see link below: The link is a bit old, but is still useful... http://www.digitalfaq.com/media/dvdmedia.htm Optical, Blu-ray: It is possible today, BUT is a bit expensive for the burner and media. In a few years, I believe this will be the system of choice. Flash Memory: Possible, but still expensive. I did see 8 GB USB Flash sticks currently on sale at Circuit City $50. That's still expensive, but in 6 to 9 years, the size will be about 8 to 64 times larger for a lower price. Bob Diaz |
#17 |
Posts: n/a
Thanks, Bob, for the break down. I would love to go solid state or blu-ray but at the current time, it is very expensive.
I've decided to go with the hard drive and double layer DVD. I figured that I would only backup the real important footage to a DL DVD media since it's going to take more time writing/reading and more medias. |
#18 | |
I know it's untested, but I am willing to believe that the shelf life of non-operating drives is much longer than 3 to 7 years if stored properly. Of course the protocols/interfaces themselves are ephemeral (SCSI, for example, and now IDE/ATA), so it's a good idea to transfer your data to the latest and greatest at certain intevals. In 7 years I will probably be able to fit all of my current archives on one drive, as you imply. Last edited by Eric Pascarelli; March 25th, 2008 at 07:33 AM. |
#19 |
Posts: n/a
So it seems that DVD media, if store properly, will last longer than hard drive, I assumed? However, the only problem with DVD media is as mentioned above, read/write speed is still quite slow for video backup.
