#241 |
BTW, Tom's pictures above remind me of another phenomenon I'm not sure whether somehow related to the IR problem: while the blacks of fabrics (and alike) materials tend to show brownish, I've noticed that black and "cold" materials (like polymers, or glossy leather) often adopt a somewhat greenish hue (I'm NOT talking about the frame extremities, coincidence angle side-effect of the IIR cut filters; also, this happens in daylight as well, while the IR contamination is most pronounced with tungsten lighting).
Anyone noticed that?
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#242 |
#243 |
Tom (edited.. originally said Steve), I would say the difference between your two shots is down to 3 things. The white balance difference (as has already been discussed), the fact that the cameras are shooting at different angles relative to the sun and the different colour matrices the two cameras use. If you colour balance the images in Photoshop they both come out looking remarkably similar, including the blacks. IR contamination is much less of an issue under sunlight anyway.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
#244 |
#245 |
OOPs my apologies Steve! This thread is just toooooo long :)
#246 |
Steven (or anybody), would gelling a tungsten lamp to raise the color temp possibly reduce the IR contamination problem? For example, if you were shooting an indoor interview and there was a lot of ambient light getting into the room, would adding a CTB or 1/2 CTB reduce the IR any at all?
#247 |
Dave, I imagine it would, but by how much, I'm not sure.
It would be great for someone to set up a test tunsgsten with increments of CTB and compare the results. Or just plain tunsgsten bulb (white balanced), then switching lights to daylight balanced bulb (white balanced). If this has already been tested, I would be interested in the results. |
#248 |
I'd be willing to try it if I can get some time in my buddy's studio some time soon. I'd be testing this with a Lowel Rifa light so I'm not sure what effect the diffuser panel would have. When I first got this softbox, I noticed right away that the black baseball hat my subject was wearing came out as a very dark brown so I guess the diffuser panel doesn't block IR to any appreciable degree. I might test this with one of the FL heads that can be swapped on the Lowel light too......if I can get my hands on one! ;-)
#249 | |
For indoors, my Sony LED light (5600K) also allows to avoid it almost completely, but it's ugly on human faces. I'll repeat my question; is the greenish cast to "cold" blacks (equally seen here in sun and tungsten light) also related to the IR contamination ? Did anyone notice that?
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive Last edited by Piotr Wozniacki; October 11th, 2008 at 02:57 PM. |
#250 |
I think I mentioned it before in this tread, I took a picture of a Black metal chair covered with black matérial.
The tissue is brown instead of black but the metal parts legs and backrest came out perfectly black So personally I would think that the greenish issue you are mentioning has no common ground with the IR problem |
#251 | |
#252 | |
Ryan ...
#253 |
What's the latest on the 77mm IR-CUT filter for the EX1?
Is there a good solution that does not have the green shift issue at wide? |
#254 |
Tom- Literally 15 seconds with the wanky color adjusting tools in "Preview" on the web create a perfect match on those 2 stills.
#255 |
Just watched a BBC TV show (Strictly come dancing) and noticed that the Judges on the show all appeared to be wearing very brown looking suits. Looks like IR to me and this is a top end HD studio shoot.
