Filters with your EX1
Just thinking about picking up some filters for my camera and wanted to see what other EX1 shooters are using?
UV-Haze Polarizer Soft focus
Jamie Baughman |
In use
ND Filters Ready just in case Close up filter Diffusion filters Graduation filters Polariser Various assorted like a fog filter etc. |
#3 | |
Have you ever used a low contrast filter to get a film look in very bright light? |
Michael. I have three Tian ya organic glass ND filters. One two and three stops. They are 3 1/2" by 4". I use with a cokin adapter. Also a 77mm screw on 4 stop ND filter that came with a krasnogorsk 16mm camera. A blue red and fog graduation filters. Some colours but not likely to get used. No I have never used a low contrast filter.
#5 | |
Sponsor: Schneider Optics
http://www.schneideroptics.com/Ecomm....aspx?CID=1431 http://www.schneideroptics.com/century/filters/dvd.htm Ryan Avery Schneider Optics |
#6 |
Ryan, thanks for the links. Can you also link the 77 mm filters? Thanks!
Jamie Baughman |
#7 | |
ND0.6 77mm Graduated: http://www.schneideroptics.com/ecomm...D=679&IID=3258 ND0.6 77mm Solid: http://www.schneideroptics.com/ecomm...D=679&IID=3260 Polarizer: http://www.schneideroptics.com/ecomm...D=680&IID=3264 Black Frost 1/2: Stock Code = 68-083277. List Price $160. Skintone enchancer: Stock Code = 68-108177. List Price $160. UV Filter for protection of lens: http://www.schneideroptics.com/ecomm...D=681&IID=3234 Ryan Avery Schneider Optics |
#8 |
Ryan,
Just out of interest - do any of these fit under the lens hood on the EX1? Also how do you ensure the horizon line is correct on the grad ND - does it rotate? Thanks in advance,
Graeme |
#9 |
Ryan,
I really wish you guys would make a 102mm polariser for the frount of the upcoming 1.6x extender - i shoot 95% outside location on a beaches and by the ocean - having a mattebox is a no go for me - apart from the weight and setting up time the main problem is that it adds volume / bulk to my camera which means more wind resistance and therefore more vibration - shooting at full zoom in the wind is hard enough as it is. Then there is the point about it won't fit under my rain cover and is therefore exposed to sea air. |
#10 | |
This polarizer is made with our Tru-Pol technology that is 12 times more effective than the best polarizer from any other brand. It features an extinction ratio of 374 vs other brands that top out around 32. This means that you can more effectively polarize the light at any angle from the light source instead of a very limited range. This creates better color saturation and reduction of highlights and reflections at almost any angle where with other polarizers you have to be mindful of the angle of the light source to your optical axis. Ryan Avery Schneider Optics |
#11 | |
#12 |
Contributor
Is your 77mm polarizer a "Tru-Pol" unit, Ryan?
Carroll Lam |
#13 |
I'm quite annoyed that the hood makes it impossible to use a polarizer.
Now I have to buy a shade as well and the ones that I've seen available are nowhere near as good as the shade in the camera. On the HVX you can still turn a polarizer with the hood on. Just another example of not consulting real camerapeople when they design these things. |
#14 |
The 77mm is available in our B+W brand or our Schneider Tru-Pol brand. Both are essentially the same laminate and feature a very high extinction ratio. We manufacture the Tru-Pol brand to differentiate the market here in the US for our Schneider Motion Picture and Television Filters. Both are excellent so the major difference in a screw in filter only is that the Schneider Tru-Pol is an aluminum ring and the B+W filter is a brass ring which is easier to mount on the camera and features a better lubrication. This is not an issue with Square or 4x5.65 filters as they have no ring and therefore are only branded Schneider.
#15 |
Contributor
Thanks for the info, Ryan!
Carroll Lam |
