WB Offset in PP = Same as Warm/Cold Cards? at DVinfo.net
Old January 27th, 2008, 12:37 PM   #1
Does setting the WB offset in the picture profile settings have the same effect as balancing on colored cards? Can it be used in place of warm/cold cards?
Michael H. Stevens is offline   Reply With Quote
Old January 27th, 2008, 01:30 PM   #2
Well since you can adjust Kelvins manually to whatever you want you pretty much have full control.
Tuomas Sebastien is offline   Reply With Quote
Old January 27th, 2008, 02:01 PM   #3
Occasionally I measure the white balance first, go into picture profile settings and adjust the white balance manually (higher Kelvin setting to make the picture warmer) and after that I use this preset setting. Works fine.
regards,
Erwin
Erwin van Dijck is offline   Reply
