2 EX1 + FCP + KONA LH questions - Page 2 at DVinfo.net
Old January 28th, 2008, 12:16 AM   #16
I used an easy setup for the project XDCAM VBR 1080 24P (something like that).
It's not pro rez.
When I would edit with HVX200 footage captured using 24 pn (only 24 p - no pull down), I would set my Kona Card to 720 P 59.97 DVC PRO HD (something like that). The Kona would play that just fine, so I think that Jeremy is right.
The footage was imported with the XDCAM import/FCP tool. I shot it as EX1 1080 24P footage (best quality).
I am not sure what is going on. I'll keep looking over my settings. I opened up a few other projects and they all go out of sync. I did not notice it before because they were just scenic shots. This new footage/project has people talking in it. It's obviously messed up. I am hoping that it's just a Kona thing and that my footage is fine.
Jay Morris is offline   Reply With Quote
Old January 28th, 2008, 02:28 PM   #17
HDV Cinema
When you said out of sync I assumed you meant VIDEO sync. Are you saying it is AV sync???
Old January 28th, 2008, 05:33 PM   #18
Oops! I meant lip sync. The audio plays in real time. The video lags behind (looks like slow motion).
Old January 28th, 2008, 06:58 PM   #19
HDV Cinema
I wonder if you are taking the audio from the Mac or from the Kona. It should/must come from the Kona.
Old January 28th, 2008, 10:47 PM   #20
The audio comes from the Kona.
It's not just out of sync, but the audio is running at real time and the video is behind and playing at a slow speed (kind of like slow motion).
I love this camera, but Final Cut Pro seems to have some issues with it. Besides the audio/video sync issue with the Kona, I often get the dropped frame error often (I think thats what it's called -- when the timeline stops playing) AND the xdcam transfer program makes duplicate browser items of each clip I import. This is very annoying.
Let me know if you guys figure out how to fix any of these problems. It could be user error!
I see a lot of people shoot in 720p with this camera. Is that to avoid these issues?
Old January 29th, 2008, 05:50 AM   #21
HDV Cinema
I'll bet your computer and/or disk is simply too slow for 1920x1080 HD. Run the Kona system checker.
And, yes I've seen duplicate clips. Not a big deal.
Old January 29th, 2008, 01:24 PM   #22
Here's what AJA had to say:
Hi Jason,
XDCAM playback is not supported however is should work.
1) Go to FCP audio video settings and set video playback to AJA Kona
1080i29.97 8-bit.
2) Go to FCP system settings -> playback control and set video quality to
HIGH and frame rate to FULL.
3) If Kona is install in a Mac Pro:
a) Install Kona in slot 3.
b) Go to: /system/library/core services/
i) Run the expansion slot utility
ii) Configure PCIe slots for: 16:1:4:4 (option 2)
iii) reboot.
Let us know if you need additional support.
Best regards
Rudy
I WILL TRY IT OUT SOON AND LET YU KNOW!
