Are the HD Analog Component and HD-SDI outputs live simultaneously? at DVinfo.net
Old January 25th, 2008, 11:47 AM   #1
Hi all,
Was wondering if the HD Analog Component and the HD-SDI output connectors are live simultaneously?
For instance, HD Analog to an onboard monitor, and the Uncompressed HD-SDI to a recording device...
Lonnie
Lonnie Bell
mamas boy productions
Las Vegas, NV
Lonnie Bell is offline   Reply With Quote
Old January 25th, 2008, 12:45 PM   #2
Yes they are.
Vince Gaffney is offline   Reply With Quote
Old January 25th, 2008, 09:31 PM   #3
Thanks Vince...
Have you used it this way?
And is the HD Analog a little soft in the monitor compared to the lcd or does everything look great??
Lonnie
Lonnie Bell
Las Vegas, NV
Old January 26th, 2008, 07:52 AM   #4
I just plugged them both into monitors at the same time to answer your question. HDSDI into a Marshall and component into a Sony 23" LCD.
They looked fine, although I didn't get real critical and was messing with my Letus at the time.
Vince
Old January 26th, 2008, 08:00 AM   #5
I really appreciate the test and your time!
Thanks Vince,
Lonnie
Lonnie Bell
Las Vegas, NV
Old January 26th, 2008, 12:11 PM   #6
Has anyone successfully taken 10bit 4:2:2 from the EX1 HD-SDI port directly into PremierPro (or any other 10 bit editor) with a hardware card like the V3HD?
Michael H. Stevens is offline   Reply With Quote
Old January 26th, 2008, 12:43 PM   #7
I have previewed in FCP the HDSDI through a Kona LHe. As far as capturing, my drives are not set up for uncompressed HD. The preview looks great as does the signal into the Marshall LCD panel.
Vince
