Questions about SDI-output in SD-mode at DVinfo.net
Old January 24th, 2008, 03:55 PM   #1
I might be using my camera in a couple of days to shoot a couple of short interviews that will be aired only a couple of hours after they are shot. The plan is to use the SDI-output and record straight into an Avid using an SDI-mojo. I have not used the SDI-output before and have the following questions:
1. What is the quality like on the downconversion to SD?
2. Is audio embedded in the SDI-signal?
3. Can I record in any resolution/framerate and simultaniously get output to SD-SDI or are there any limitations that I should know about?
4. Anything else I have not thought about?
Very grateful for any advice I can get!
/ola
Ola Christoffersson is offline   Reply With Quote
Old January 25th, 2008, 03:05 AM   #2
**BUMP**
Sorry to be persistent. I need the answers to these questions today to be able to make a decision. No one knows?
Old January 25th, 2008, 09:34 AM   #3
Audio is embedded in the SDI. I've been using it this way with the BM HDLINK.
Old January 26th, 2008, 03:03 AM   #4
Thanks Steven!
Any thoughts on the SD-downconversion quality?
Old January 26th, 2008, 03:24 AM   #5
Originally Posted by Ola Christoffersson View Post
Thanks Steven!
Ola,
regarding quality. I played with the camera for more than a week and i must admit that i am quite impressed. i saw the whole picture on the +-50" screen and hd quality is fantastic.
SDI also in my opinion looks very very good in SD mode. anyhow you should test it for yourself of course.
personally i will use it with no problem.
all the best,
filip kovcin
in kino (sic!) veritas
Filip Kovcin is offline   Reply
