Q about ExpressCard & Mac Pro at DVinfo.net
Old January 23rd, 2008, 02:57 PM   #1
If I'm editing on a Mac Pro, what is the path from the Expresscard? I am assuming I would want the Sony USB card reader. Is there a plug-in for the Mac Pro that can directly read these cards?
(I understand that in the field, I would want something as well, ideally a notebook and large disk, but I'm trying to understand this piece first)
Jim McQuaid is offline   Reply With Quote
Old January 23rd, 2008, 03:11 PM   #2
The camera has a USB port on it so you can plug the camera right into the computer if you want. Although the port is in the hardest possible to reach location.
Also, you would need to make sure the camera is either plugged in or has enough battery to download all the footage without going dead.
Andrew Wilson is offline   Reply With Quote
Old January 23rd, 2008, 04:11 PM   #3
Curious about this
http://www.synchrotech.com/products-...-drive_03.html
It MIGHT work but someone would have to experiment. The description implies it might work on non Windows boxes and at the bottom they link to SxS drivers comment stating it's untested.
Old February 10th, 2008, 01:57 PM   #4
I am willing to believe that since the SxS cards theoretically work on the pci-e bus capability that this adapter should work. I also believe that this adapter should work on the mac pro. The os knows how to handle expresscard by default due to the Macbook Pro and since on the Macbook Pro the expresscard 34 runs through a pci-e bus, it is a relatively safe bet that the Mac Pro would handshake pretty well with this device. My BIG fear from this thread is that the SxS does not speak the same language as either the expresscard usb ssd or pci-e ssd. Those two run without any driver on osx. The sony driver makes me believe that they are running on some custom headers. Does that eliminate the possibility of 3rd party (excluding sandisk) ssd working with the EX or does it just mean that the formating of the cards is specific to the EX?
I Will test all of these things together as soon as I get my EX (around a month). Hopefully someone else does before me.
Joshua Fleetwood is offline   Reply With Quote
Old February 10th, 2008, 03:45 PM   #5
PCIe card for Expresscard reading on Mac
I've seen a post on the FCP board from someone who reports that the PCIe adapter card for the Mac Pro works fine with the SxS cards for import.
Check out Turnip Films
www.turnipfilms.com
Old February 10th, 2008, 04:31 PM   #6
Ben reports having trouble swapping cards in this thread op the board. The Synchrotech's device doesn't explicity support Mac Pro's, but should work in principle. Not sure about hot-plugability though.
Be sure to add the Sony SxS drivers listed at the bottom of your specs page. That may be crucial for the hot-pluggable problem.
I'll drop a post in Benjamins thread about the drivers, might actually solve his problem.
George/
George Kroonder is offline   Reply
