Picture Profile Recipes - Page 8 at DVinfo.net
Old January 31st, 2008, 07:09 AM   #106
I always either use a colour meter or a white balance to a card first!
Using Bills settings I get a true look. In fact the best of all profiles I have seen. However when colour correcting in post. First using colorista to further white balance if neccesary. Then color finesse in HSL mode I can get a really nice effect with the cameras own color balance. The thought crossed my mind I wonder if the camera is set this way for Colour grading. Probably not.
Mark David Williams is offline   Reply With Quote
Old January 31st, 2008, 07:33 AM   #107
help
ok i'm a little confused...
I'm using a mac
So I should download the .suf file from chris..
If so how do I do that, when I try it wants to save as a php file.
Then what o I do with it and how do I put this into the camera...
Robert Musiello is offline   Reply With Quote
Old January 31st, 2008, 07:46 AM   #108
Piotr. I just realised how my original post reads! I shouldnt have said colour balance. "Although that describes it correctly" .But the standard colour settings of the camera. Because you have to balance them to get right!
Old January 31st, 2008, 07:53 AM   #109
Yes Mark, I think I did get you right - and hope you got me right as well (sorry, English is not my native language).
Old January 31st, 2008, 09:04 AM   #110
Piotr. I meant Bills settings. The colours here
Matrix ...............on
Select................hisat
Level..................0
Phase.................-5
R-G...................75
R-B...................0
G-R...................-18
G-B...................-32
B-R...................-27
B-G...................13
Old January 31st, 2008, 12:51 PM   #111
Yes, I like Bills last profile TC2.
This seems to work good in bright light.
Bill, how do you feel about having possibly three of these profiles.
bright, moderate, and low light?
They all would remain on CINE1, but I imagine all that would need to be changed is the gamma and black levels for each profile.
Old January 31st, 2008, 01:17 PM   #112
Images: 10
Steve...
Makes sense to me. As I said earlier in this thread, I dropped the CINE1 gamma levels from 0 to -40 to get the middle gray values at 50% IRE on the WFM. The STD3 profile was much closer. I had to drop the LEVELS to -15 to get middle gray at 50%. I was set at a fixed f/4.0 and 1/60 sec exposure for my tests. Knowing that, if one stays with the CINE1 preset, my recommendation is that you experiment with different GAMMA LEVELS, varying between 0 and -40, depending on what suits you for varying light conditions.
The other CINE presets were quite surprising at how MUCH they stretched the blacks and compressed the hi-lights. Having seen that, I doubt I'll use them much.
Old February 1st, 2008, 09:55 PM   #113
Isn't black stretching and compressing whites to avoid blow-out and to give a flat low contrast film look middle what most users are after?
Michael H. Stevens is offline   Reply With Quote
Old February 2nd, 2008, 06:40 AM   #114
I'm thinking the same...
Dennis Schmitz is offline   Reply With Quote
Old February 2nd, 2008, 06:50 AM   #115
Yes it is; however, in low-light situations (or with dull scenery) you would want it the other way around: compress blacks so that noise in the shadow is minimized, and elevate the knee point (stretch highs) to get as much brighness into the picture as possible.
Of course I do agree that in an ideal world (and ideal camera that never introduces gain noise or black/white clipping), shooting flat and only grading in post would be preferrable...
Old February 3rd, 2008, 09:01 AM   #116
Images: 10
Been playing with the different CINE choices. Cine 1, 3, and 4 all work with the color profile I generated, but, provide different levels of black stretch. I also reset the gamma level to zero when I use cine1, 3 or 4 to open up the blacks. See Adam Wilt's opinion of each cine, progressive levels of black stretch, except for Cine2, which is a flyer.
Old February 3rd, 2008, 09:32 AM   #117
Bill, are you saying that your new profile is:
Gamma Level.............. 0 (changed from -40)
Gamma Select.............CINE1
Black..........................-12
Black Gamma..............0
If so, this will probaby help the crushed blacks. I noticed the blacks were a bit crushed in your last -40 gamma setting. Well, at least in low light.
Old February 3rd, 2008, 09:48 AM   #118
Images: 10
Steve...
yes! You lose a little dynamic range, but, it takes less CCing in post. And selecting a CINE1, 3,or 4 setting, depending on how much black stretch you want/need.
I think part of the lesson, here, is that the color matrix settings are good for a truer color, however, the way Sony applies gamma curve settings is a learning process for me.
One thing about my old settings is that the auto iris tends to underexpose unless one manually adjusts the iris for 100% zebra. It seems to be equivalent to something less than 1/2 f/stop since adjusting the level in TLCS by +0.5 is too much.
Your observation that light level effects things is right on.
Old February 3rd, 2008, 10:29 AM   #119
Thanks Bill.
I'm going to make three TC files.
TC1 (CINE1)
TC2 (CINE3)
TC3 (CINE4)
Gamma Select.............(CINE1, CINE3, or CINE4)
Thanks for your time Bill.
Old February 3rd, 2008, 10:31 AM   #120
Images: 10
Steve...
Already done that...here
pp1: Steve Thomas' PP
pp2: original TC1
pp3: TC2 Cine1
pp4: TC2 Cine3
pp5: TC2 Cine4
pp6:TC2
note; you have to rename the suf file to "setup.suf" before loading it onto your SxS.
Bill Ravens is offline   Reply
