Picture Profile Recipes - Page 10 at DVinfo.net
Old February 4th, 2008, 01:21 PM   #136
Originally Posted by Michael H. Stevens View Post
YES. All the STD gammas are bright and contrasty and generic looking. No need to ever use them.
Michael. no offence but your answer is a generalization and as such doesn't satisfy me. The STD gammas, while "generic looking", are usually the safest ones (thus becoming the factory default) - so what happened here is a bit of a surpise...
Anyway, which of the other parameters that differ from the factory settings (hisat matrix, or the matrix color pairs changes) could have caused the oversaturation and then abrupt blowing-out of highlights (cause this is how I'd describe what's happening to the blue behind the tree branches)?
Any opinion welcome. Unfortunately, I do not have means to test it step-by-step using even a good, calibrated monitor - not t mention the WFM that Bill was using...
Old February 4th, 2008, 01:34 PM   #137
Images: 10
Piotr..
By all rights, your question should be moved to another thread. This one is for profiles. I will suggest, for now, that you check your DETAIL and CRISPENING settings. DETAIL ON will sharpen the image causing halo if overdone.
Old February 4th, 2008, 01:43 PM   #138
Originally Posted by Bill Ravens View Post
Piotr..
OK Bill, I will - but my settings are exactly what you suggested in your own post
http://www.dvinfo.net/conf/showpost....9&postcount=64
(this thread), and in it you said "It would be great to have someone validate my results". This is what I was trying to do; and believe me I entered the settings, exactly following your recipe (no DETAIL or CRISPENING changes).
At least could you please confirm you can see the problem in my first grab, and if so - what is the English name for this abrupt clipping of oversaturated highlights? Is it a normal behaviour with the STD3 gamma whose default Knee Point SATURATION is as high as 50? As you can see in my sig, I am still learning so your help would be much appreciated...
Old February 4th, 2008, 02:46 PM   #139
Piotr hope you dont mind me commenting!
How I saw this was a combination of two colour temperatures in the foreground and background. Also the clouds were overexposing the image. Perhaps a poloriser or a graduated ND filter? I'd like to have seen a picture at standard settings to compare.
Mark David Williams is offline   Reply With Quote
Old February 4th, 2008, 03:29 PM   #140
No, of course not Mark - you're welcome.
I'm seeing a serious problem here (either with the settings or my camera), but let's take the discussion elsewhere, as Bill suggested:
http://www.dvinfo.net/conf/showthrea...095#post820095
Thanks;
Piotr
Old February 4th, 2008, 03:37 PM   #141
OK - I have just read this complete thread and I must say that it is all a bit over my head. However I am very eager to try out Bills settings for myself. On the last couple of pages of the thread the settings seemed to branch out into a few variations and I cannot really make out the exact settings that Bill ended up with. Bill - could you please post the exact settings that you are now using along with a very brief description or comment on each setting? That would be very helpfull! I would rather not download your file and loose all of my camera settings loading it into my cam.
Thank you again for your hard work! Hoping to try out your settings on wednesday.
/ola
Ola Christoffersson is offline   Reply With Quote
Old February 4th, 2008, 03:55 PM   #142
Images: 10
Please see post #120. I've already done as you asked.
Old February 4th, 2008, 04:25 PM   #143
Piotr (and others) you CAN monitor these settings while they are being made either with a good monitor or later in post because you can adjust any of the settings on EX1 WHILE RECORDING. So set your camera up with that scene again and start tweaking. There is no meta data so you will need give a commentary for when you review later.
Michael H. Stevens is offline   Reply With Quote
Old February 5th, 2008, 01:31 AM   #144
[QUOTE=Bill Ravens;815954]I've reworked my original profile based on some feedback and observations I received. It was suggested I use a CINE profile for gamma, reds have been dialed down, black level was raised, slightly. Overall, this is an improvement, I really like this profile, altho' my test was quick. I've posted a framegrab, so the comparisons are here:
factory setting(PP Off):
http://www.dvinfo.net/gallery/showimage.php?i=801&c=2
My TC1 profile:
http://www.dvinfo.net/gallery/showimage.php?i=802&c=2
My TC2 profile:
http://www.dvinfo.net/gallery/showimage.php?i=826&c=2
And the recipe is:
Matrix ...............on
Select................hisat
Level..................0
Phase.................-5
R-G...................75
R-B...................0
G-R...................-18
G-B...................-32
B-R...................-27
B-G...................13
Gamma Level..............-40
Gamma Select.............CINE1
Black..........................-12
Black Gamma..............0
Once again, please set your white balance before using. Let me have feedback on your use of the profile.
By the way, Chris, I tried to upload the .suf file and the server still won't let me.[/QUOTE
Last edited by Cody Stanton; February 5th, 2008 at 02:28 AM. Reason: Accidently posted my message in someone else's page. Sorry,I'm a new member.
Cody Stanton is offline   Reply With Quote
Old February 5th, 2008, 02:23 AM   #145
Picture Profile For Night/low Light Shooting
I just used Bill Ravens Picture Profile exactly as detailed with the Gamma Level changed to 0 instead of -40 and results were fantastic. This was done outdoors on a bright but overcast day.I'm sure Bill's settings are also great for a sunny day. But can anyone tell me if I need to make any changes to these settings if I'm sooting outdoors at night in low light conditions?
Any help will be greatly appreciated.
Old February 5th, 2008, 03:07 AM   #146
Sorry Bill - I was probably unclear. I am aware of the .suf-file in post #120 but I would rather not download it and loose all of my own camera settings. What I was hoping for was all the current settings in text in a post with comments, especially on when to use the different gamma curves. For example I am not sure what gamma value to set when not using cinnegamma curves. And which gamma curve and setting should be used if I don't want to change the cameras default gamma and only use your new colour settings? I am sorry if this all sounds daft. I have been trying to figure it all out by reading the whole thread but I have a feeling that the introduction of the cinnegamma curves got me confused.
Old February 5th, 2008, 07:17 AM   #147
Piotr..
Bill,
I recreated tests with your STD3 and Hisat matrix PP, and the bottom line is that - with standard KNEE settings - it's no good for even slightly backlit situations. To avoid the higlights clipping unstability (i.e. staying saturated behind the "shadow" of e.g. trees, while blowing-away to pure white elsewhere, thus creating the ugly patches), one must stay way into the left exposure side, which tends to badly oversaturate even slightly underexposed areas.
The PP in question might be of some use, but requires KNEE adjustment. Will be playing with that and report.
Thanks everyone for their response, and sorry if my post has been a little bit too much alarming - didn't want to highjack "your" thread :)
Old February 5th, 2008, 09:41 AM   #148
Originally Posted by Ola Christoffersson View Post
What I was hoping for was all the current settings in text in a post with comments, especially on when to use the different gamma curves. .
I second this. A textual summary of info to date with NOTES on when applicable posted by those who know best would be great.
Old February 5th, 2008, 10:19 AM   #149
I believe Adam Wilt's own characterizations of the gammas gives us a good idea of where the knee kicks in for the cine gamma curves. Thank you to Adam for providing this information. It would of been nice if Sony provided some detail.
http://provideocoalition.com/index.p..._camcorder/P3/
Old February 9th, 2008, 07:01 AM   #150
So - I have done two days of testing of the TC2-profile now and I will not be able to turn back to the original settings!
I have to admit that I was a bit afraid that these settings would only be "for effect" and that I would lose information using them. My first tests seemed to confirm these fears. The pictures looked very good but also very crushed and a bit over saturated. However after doing more tests on a sunny day and looking at the results in Avids Waveform monitor I am not worried anymore. I am not a video-signal-techy but to me it looks like the Cinegamma curves move all of the information into the 16-234 IRE-range without anything disappearing. The standard setting has a lot of info above allowed white and it seems to push the blacks up a bit too high, leaving no info in the bottom region.
As I said, I am not good at the theoretical part of this so correct me if I am wrong. Also I am blabbering. The reason for this post is to ask a couple of question to all of you who now more about PP and gamma curves than me.
Here it goes:
1. Are the Cinegamma 1,3 and 4 basically curves that give the same "feel" but to a different extent? In other words - can I switch between these curves depending on lighting and weather conditions and still intercut between the pictures or am I supposed to select one Cinegamma on each project?
2. If so - am I correct in saying Cinegamma 1 in high contrast light (sunny day) and Cinegamma 4 when overcast or is it the other way around?
