Look inside the XML - cachRec ? at DVinfo.net
Old December 21st, 2007, 02:07 PM   #1
I'd thought some might want to see what's in the XML from the source.
<?xml version="1.0" encoding="UTF-8"?>
<NonRealTimeMeta xmlns="urn:schemas-professionalDisc:nonRealTimeMeta:ver.1.20" xmlns:lib="urn:schemas-professionalDisc:lib:ver.1.20" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" lastUpdate="2007-12-19T23:42:57-05:00">
<TargetMaterial umidRef="060A2B340101010501010D4313000000BA234032544405C50800460202280328"/>
<Duration value="521"/>
<LtcChangeTable tcFps="30" halfStep="false">
<LtcChange frameCount="0" value="12010000" status="increment"/>
<LtcChange frameCount="520" value="22180000" status="end"/>
</LtcChangeTable>
<CreationDate value="2007-12-19T23:42:39-05:00"/>
<TypicalUbit value="0000000000000000"/>
<BodyUmidBasicChangeTable>
<BodyUmidBasicChange frameCount="0" value="060A2B340101010501010D4313000000BA234032544405C50800460202280328" status="start"/>
</BodyUmidBasicChangeTable>
<KlvPacketTable>
<KlvPacket key="060E2B34010101050301020A02000000" frameCount="0" lengthValue="095F5265635374617274" status="spot"/>
</KlvPacketTable>
<VideoFormat>
<VideoRecPort port="DIRECT"/>
<VideoFrame videoCodec="MPEG2HD35_1920_1080_MP@HL" captureFps="29.97p" recFps="29.97" formatFps="29.97p"/>
<VideoLayout pixel="1920" numOfVerticalLine="1080" aspectRatio="16:9"/>
</VideoFormat>
<AudioFormat numOfChannel="2">
<AudioRecPort port="DIRECT" audioCodec="LPCM16" trackDst="CH1"/>
<AudioRecPort port="DIRECT" audioCodec="LPCM16" trackDst="CH2"/>
</AudioFormat>
<Device manufacturer="Sony" modelName="PMW-EX1" serialNo="0100808">
</Device>
<Lens modelName="XT14X5.8"/>
<RecordingMode type="normal" cacheRec="false"/>
</NonRealTimeMeta>
Old December 21st, 2007, 02:08 PM   #2
<NonRealTimeMeta xmlns="urn:schemas-professionalDisc:nonRealTimeMeta:ver.1.20" xmlns:lib="urn:schemas-professionalDisc:lib:ver.1.20" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" lastUpdate="2007-12-20T01:23:13-05:00">
<TargetMaterial umidRef="060A2B340101010501010D4313000000749F1344544405DC0800460202280328"/>
<Duration value="16"/>
<LtcChange frameCount="0" value="15570000" status="increment"/>
<LtcChange frameCount="15" value="00580000" status="end"/>
</LtcChangeTable>
<CreationDate value="2007-12-20T01:22:55-05:00"/>
<TypicalUbit value="0000000020120720"/>
<BodyUmidBasicChange frameCount="0" value="060A2B340101010501010D4313000000749F1344544405DC0800460202280328" status="start"/>
<KlvPacketTable>
</KlvPacketTable>
<VideoFormat>
<VideoFrame videoCodec="MPEG2HD35_1920_1080_MP@HL" captureFps="01.00p" recFps="29.97" formatFps="29.97p"/>
</VideoFormat>
<AudioRecPort port="OTHERS" audioCodec="LPCM16" trackDst="CH1"/>
<AudioRecPort port="OTHERS" audioCodec="LPCM16" trackDst="CH2"/>
</AudioFormat>
</Device>
<RecordingMode type="slowAndQuickMotion" cacheRec="false"/>
</NonRealTimeMeta>
Old December 21st, 2007, 02:12 PM   #3
The first is from 1080p30.
The second is from 1080 at 1fps slow and quick mode.
The interesting thing is there seems to be an allusion to cacheRec which is set to false.
Makes you wonder.
Old December 21st, 2007, 11:19 PM   #4
Fascinating read... :-)
No, for real, and what are we looking at here?
www.ascentfilms.com
Jiri Bakala is offline   Reply With Quote
Old December 22nd, 2007, 12:10 AM   #5
XML file which describes the clip inside the BPAV folder. Each clip (.MP4) has an associated .SMI, .PPN, .BIM, XML file. The XML files has all sorts of info describing the clip. Data.
I'm wondering what that cacheRec really is. Nothing I've tried yet changes it from false to true.
I have a fantasy that Sony was/is looking at a cache record function that will buffer video before one hits record. I could be mistaken though. I'm wondering if anyone has found something that enables the setting (meaning it's something other than what I'm thinking).
Old December 23rd, 2007, 01:25 AM   #6
Craig, That would be killer if they can enable this feature with an upcoming firmware update.
Jason Bodnar is offline   Reply With Quote
Old December 23rd, 2007, 09:21 AM   #7
Images: 1
That's what it is. The XDCAM HD cameras didn't have it with the early firmware, but it was added later. The XDCAM SD cameras have it also.
So you may get it later on in a firmware update.
-gb-
Old December 23rd, 2007, 09:33 AM   #8
Thanks Greg. A while back a few Sony reps were saying cache recording would be enabled in a firmware update but later they (ones that I talked to) said they wouldn't promise such a feature would be implemented. It made me think that they ran into an issue. The early comments said it would be two seconds. I still hope for it though.
Old December 23rd, 2007, 09:38 AM   #9
Images: 1
I think what happens is after the product release, the programmers keep looking at ways to optimize the code, thus allowing more functionality to be added without breaking everything else in the process. Just like with graphics cards, the first run of the drivers are usually followed by more optimized drivers later on, translating into better performance.
They are still planning more firmware updates to the F350, but the timeline isn't cast in stone.
-gb-
Greg Boston is offline   Reply
