Lens protection for EX1 - Page 3 at DVinfo.net
Old December 22nd, 2007, 04:51 PM   #31
also to confirm w/ what I've got working or not w/ the lens hood:
- the Hoya 77mm "Both Sides Coated" UV WORKS
- the Hoya 77mm "Pro1 Digital Protector" (clear) WORKS
- the Hoya 77mm "Cir-Polarizing" DOES NOT WORK (too thick a bezel)
Keith
Keith Rollinson is offline   Reply With Quote
Old December 23rd, 2007, 02:25 PM   #32
Tiffen
I bought a Tiffen clear lens for the EX1 and the lens hood would not fit over it. So I did the unthinkable... I filed down the edges of the filter... and sure enough, the lens hood barely makes it over.
Threads still good too... I attached a 77-72mm stepdown ring (with the hood off of course) and everything is dandy.
John Hess is offline   Reply With Quote
Old December 23rd, 2007, 04:20 PM   #33
Keith,
Hoya Pro 1 Digital Circular polariser does work - its just a little hard to turn. It is much lower profile than the other Hoyas - which as you said will not fit.
Graeme
Graeme Fullick is offline   Reply With Quote
Old December 23rd, 2007, 04:44 PM   #34
Just got the B+W 66-1001705 Clear Glass from Adorama. Fits Perfectly. No problem at all getting the lens hood on. They also have the Hoya Pro 1 Digital Protector clear in stock.
Old December 24th, 2007, 10:57 AM   #35
Hi Graeme,
Thanks for that -- I'll try to trade my non Pro1 for a Pro1. Of course, w/ the lens hood attached it makes adjustment of the circular filter a little difficult...
Old December 24th, 2007, 12:57 PM   #36
Can you reach inside the hood to adjust a polarizing filter, or do you have to take the hood off?
Pete
Clark Peters is offline   Reply With Quote
Old December 24th, 2007, 02:46 PM   #37
Pete
You have to take it off, but it comes off quick.
Old January 9th, 2008, 07:06 PM   #38
Images: 2
Linear Polarizer
Can anyone recommend a linear polarizing filter that fits the EX1 without removing the hood other than to adjust. I take it the Tiffen 77MM LOW-LIGHT LINEAR POLARIZER Item Number: 77LLPOL is too fat.
Thanks…
John McCully is offline   Reply With Quote
Old January 10th, 2008, 03:35 AM   #39
I found a Hama clear lens,77mm,screws straight on and hood goes back on no problem.
Round 2
GH5,FZ2000
Old February 20th, 2008, 08:15 AM   #40
Just wanted to make sure whether the HOYA PRO1 Super HMC filter (ring 3 mm thick, according to the description on webpage) will fit under the EX1's lens hood.
Can anybody confirm? Thanks.
Old February 20th, 2008, 12:10 PM   #41
Linear Polarazier, a no no?
Hi all!
I think this is my first post ever, I´m from the still-photography world where you do not put linear polarizers in front of autofocus lenses,is it different on video cameras?? My EX-1 is due tomorrow, I have 77mm B+W Kasemann circular polarizer for the Hasselblad lenses, would be great if I could use this for the EX-1 as well...
Magnus Eklof is offline   Reply With Quote
Old February 20th, 2008, 03:59 PM   #42
Sponsor: Schneider Optics
Originally Posted by Magnus Eklof View Post
Hi all!
Magnus,
While you do not need a circular polarizer for virtually all video cameras on the market today, you will be fine using the B+W filter you have on your camera. I have tested them and they fit fine under the hood. Of course it will be more difficult to turn with the hood installed.
Ryan Avery
Schneider Optics
Ryan Avery is offline   Reply With Quote
Old February 20th, 2008, 04:06 PM   #43
I agree with Paul
Originally Posted by Paul Cronin View Post
After trying all the brands on my Canon A1 I am now using B+W UV double coated with excellent results. It comes in 77 mm. I have one coming with my EX1. The 4mm brass ring with front threads retail is $79
I use B+W filters and I have been very happy with the quality....even for our Canon SLR's the B+W filters are much better than Canon's best.
Craig
Craig Hollenback is offline   Reply
