Thread Tools
Search this Thread
#691 |
Thanks.
I might break down and try it. Gerald, just to confirm, you ran the BF calibration (FB) three times, right? ND OFF ND1 ND2 What did you do between each calibration? Did you power cycle? I hate to say it, but could you provide a step by step procedure on how you made this adjustment? I realize there would be a disclaimer to try at your own risk. |
#692 |
o.k. try at your own risk. Thats how it worked for me for 2 cameras Sony could not fix - your experience could be different..
Camera was set to 1080 25p PP1 with detail off I used 12 focus charts (Siemens Star) - I think a few less would not make a difference... 4 columns 3 rows Camera was 3 meters away from a white wall outside my house Aperture always f1.9 fully open at stop (use shutter to adjust brightness) Focus full manual Zoom servo on Macro set to off Set to ND off - zoom in fully - use expanded focus and sharpen Use the maintenance menu - choose backfocus adjustment (FB) When finished - leave menu - do not turn the camera off Turn on ND1 - adjust brightness with shutter zoom in fully - use expanded focus and sharpen Use the maintenance menu - choose backfocus adjustment (FB) When finished - leave menu - do not turn the camera off Turn on ND2 - adjust brightness with shutter zoom in fully - use expanded focus and sharpen Use the maintenance menu - choose backfocus adjustment (FB) no need to turn off the camera in-between adjustments. Good luck - its pretty easy to perform - I hope this will solve your backfocus problems as well. |
#693 |
Thanks Gerald. Actually my camera's BF seems OK. It may be a tad softer wide, but not much.
I'm going to really test it well before trying this calibration. |
#694 | |
http://www.mdma.tv/ex1/fb.html A crate of virtual beer to you. Sincere thanks. |
#695 |
Matt, that's impressive - however can you kindly tell me what is your firmware version of the camera? Is it 1.02 or 1.03 or 1.05? Thanks
#696 |
It's 1.03.
FWIW, SN 0401953 purchased in the UK in March 2008. |
#697 |
A big thank you Gerald for your patience.
I thought I had a perfect camera but then I had niggling feeling that the B/F was a little off. Have just carried your remedy with 12 charts just like Matt has done {even the patio doors were the same} . The result is I now have spot on backfocus. I am glad that things are sorting out the EX1 is one hell of a camera. |
#698 |
LOL!
As an addendum to this, note that I did the check on Clear, ND1 and ND2 at 720p25. Having spent so much time setting the hi tech chart up, I thought I'd just check the 1080i50. From a bit further back. Hmmm. I think I just messed up the chance to spot something important. I thought it was off, so I've just gone through every mode at all ND settings and performed a FB. It may be rather more tedious than we thought - it may be safer to open a bottle of something and do ALL modes at ALL ND settings. Or maybe it's just the equivalent of washing your car to make it rain. |
#699 |
Matt and others,
I am a little lost fellows - see if I'm following this all... You are adjusting BF within each camera setup, and within each camera setup - each possible ND setting. Now after setting new BF adjustments - is the camera electronics automatically adjusting the BackFocus according to which ND setting and which camera mode you are in... Or will you need to physically adjust backfocus everytime you make an adjustment to ND or camera mode or change the battery? Thanks for clearing things up, Lonnie
Lonnie Bell mamas boy productions Las Vegas, NV |
#700 |
Have carried out the auto procedure on each setting, clear,ND1,ND2. All done without switching off camera. When camera is powered down and the powered up again it remembers the new settings.
#701 |
thanks Bruce...
#702 | |||
Another thought that passed my mind this evening is that Patio Doors may be the perfect answer, and the 9-12 star charts weren't strictly necessary. Just something with some contrasty lines both in close up (door handle) and wide (patio door). Just pontificating. |
#703 |
Thanks Matt - and long live a fine drink, lovely evenings, and British Humor...
#704 |
The patio doors are essential. Its the ratio of backfocus charts to glass area that is the key.
Seriously though I suppose the auto back focus needs something bigger to work with. Whether the different settings are really needed is something that perhaps Sony could tell us. Having back focused Fujinon 2/3" lenses for years with just one chart the procedure now developed is intriguing. |
#705 | |
The key is 'auto' back focus. When you do your manual back focus, you know you want to focus on the chart. The camera's auto FB routine sets the zoom to wide and then focuses on the most contrasty thing in frame. If this happens to be a few feet further away than the now tiny backfocus chart, it is not surprising that the camera gets confused :-) Nick |
