#616 |
Sure thing - never give up! Sony just owes some effective fix to us.
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#617 | |
More to the point though, the dealer network and the various Sonys are not an optics company. Even the F900 has issues with lens mounts, I recall someone (Claimont?) is modding one of the high end Sony cameras to fix an ND filter issue. This stuff is harder and more expensive to get right than we might appreciate. Perhaps this is one road to persue, take the camera to a facility with optical test facilites and get a written report with facts and figures. |
#618 | |
#619 |
I got my camera back from Sony from the second repair attempt 2 hours ago - and guess what - it returned in even worse condition. Now the backfocus is horrible even with ND OFF. The camera is unusable now.
This sucks big time! I´m so p*ssed! I bought the camera 5 weeks ago and it did never really work! |
#620 |
Man, I know that feeling.
I sent my first camera in for vignetting and it came back a tad worse. instead of the vignette seen at the top two corners, it was a bit less, but viewed on all four corners. My current replacement camera has it in the top two corners, but it's not as bad as my first. I'm to dang scared to send it in for adjustment. I'm not sure if they really know how to correctly adjust it. Oddly, i've heard some say they've had success in the adjustment. I'm sorry to hear about your issue. If they can not fix the camera, it should be replaced. Also, that's odd about your back focus. Apparently, they shifted something during the work. I'm not sure why they are having a problem with back focus. My guess is they are not sure how to correctly adjust it. We are hearing more and more about back focus is bad right out of the box! |
#621 |
How to check for Backfocus issues?
I'm sure this has been asked before but I can't seem to find it-- how do you quickly and in the most simplest way, check if you are having any backfocus issues with ND filters on?
#622 |
Tip of the iceberg
We need to take action.
This is totally unacceptable and unprofessional on SONY's behalf. Today I sent my two EX1s (Netherlands Service) with the well known backfocus and vignetting problems. My experience with service (called from Athens, Greece the Prime Support in UK) from the beginning was really annoying. I was talking to a lady at Prime support when at the same time in the background you could hear screaming and loud laughters like they were having some sort of party. At some point the lady who could hardly hear what I was trying to explain to her, she paused and said "excuse me sir but there is a lot of noise in hear and I can't hear you. She put me on hold and probably she told the others in the background to shut up and then she came back on the line to continue our conversation. You tell me how professional does this sound and how can you trust THE Prime Support reps of a company when you face a situation like that, put aside the double returns and no fixes of other people's equipment. Maybe it's time act I say. We really need our equipment for our jobs and nobody can play around with our integrity (towards our clients) for so long and in such a massive way. Any thoughts welcome. |
#623 |
Can I ask, as someone who will buy the camera shortly, how big the problem is? I agree that if there are many problems that you should act, especially as you all have clients and stuff, but are there also non-faulty camera's out there?
#624 | |
This is how it worked with me V1E and DR60 last year.
#625 | |
-vignetting -ca -backfocus thanks in advance be well rob |
#626 |
Rob,
Here's a general setup to determine if your PMW-EX1 camera has the vignette issue: 1. Set the EX1 for FULL manual control. 2. Set the cameras focus at infinity. (furthest focus range). 3. Position your camera on a tripod with "Steady Shot" OFF (OIS OFF). 4. Aim your camera on a white or neutral color wall (not black). 5. Start with camera at full wide (5.8mm) and zoom all the way in and verify no objects come into your view throughout the zoom travel. 6. Do not over expose the image. Actually intentionally under expose the image. 7. Now with your camera set to wide 5.8mm focal length, start recording. 8. While recording SLOWLY zoom up to 40mm. The problem is known to be seen in the 8mm - 25mm range. So SLOWY zoom through this focal range. If you're concerned it may be an issue out of this range, you can zoom through a greater range. 9. Import your footage into your computer and look for the vignetting issue. IMPORTANT: When viewed on a monitor while recording, you may not see the issue due to the monitors overscan. View your capture footage on your computer. How to check Back Focus: 1. To allow for far focus, setup the camera outdoors. 2. With ND filters off, zoom in ALL the way and focus on a distant object over 25 feet away. Keep your aperture wide open at f1.9. Depending on the available light, you may need to increase your shutter speed to not over expose. 3. Once you've focused on your distant object, zoom out full wide. The wide image should still remain in focus. 4. Repeat this test with each ND setting. 5. Also, repeat the test focusing on the distant object without the ND filter and then engaging an ND filter when zooming out wide. The camera should remain in focus regardless of the ND setting. Last edited by Steven Thomas; March 17th, 2008 at 09:29 PM. |
#627 |
Piotr the cameras have been sent today to the Netherlands Sony service center, so I am in waiting and see kind of situation. What scares me is what I read from others (two repairs and camera came back in worse condition)
I have lots of two camera assignments lined up in a months period and I am scared ****less to the the prospect of not having the cameras in tip top condition (as they should be) when the time arrives let alone the learning curve period. I hear what you say about loaners and replacement. Who will guarantee me proper function loaners and replacements though. Sony's tracking record so far with the specific model is not encouraging. Thank you for the advice though. |
#628 | |
I know I just kept getting passed around between dealer, service agent and Sony, when I had to take my EX1 back for the vignette fix. Nobody wanted anything to do with me. I'm curious now as to whether this Prime Support applies to all EX1 customers or just some parts of the world. |
#629 |
#630 |
Sorry but I need to correct Steven's explanation of how to check backfocus
Your camera aperture should absolutely be set at fully wide open f 1.9 all the way - , not 2.8 or 4 . This is critical as you don't want to be confused by depth of field. Aside from that his method sounds fine. I do want to repeat Steven's suggestion though that you want to check this on as big a monitor as you can - so you may need to record then look at a large computer monitor. You can also focus at telephoto then change the filters to see if your focus point stays the same - Do the same wide angle. The wideangle is what we are most concerned about. That's where it will go off and you won't see it while shooting. How to check Back Focus: 1. To allow for far focus, setup the camera outdoors. 2. With ND filters off, zoom in ALL the way and focus on a distant object over 25 feet away. Keep your aperture wide open at f1.9. Depending on the available light, you may need to increase your shutter speed to not over expose. 3. Once you've focused on your distant object, zoom out full wide. The wide image should still remain in focus. 4. Repeat this test with each ND setting. 5. Also, repeat the test focusing on the distant object without the ND filter and then engaging an ND filter when zooming out wide. 6. Flip through filters and no filter after getting a good focus both at telephoto and full wide. It should remain the same. The camera should remain in focus regardless of the ND setting. Lenny Last edited by Leonard Levy; March 17th, 2008 at 10:50 PM. |
