Vignette problem - Page 33 at DVinfo.net
Old February 21st, 2008, 08:30 AM   #481
Originally Posted by Tom Hardwick View Post
I wonder when you say 'the darkened corners' Paul if you're seeing simply less exposed corners (which is quite normal at full aperture)
But if it were that, wouldn't he see the vignette as a constant presence whether he's moving the camera or not?
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply With Quote
Old February 21st, 2008, 08:43 AM   #482
In this case, since the vignette is visible, the OIS shifts this around.
I've heard of no complaints with vignetting at full wide and max aperture f1.9
The vignetting issue mainly affects 8-25mm range with aperture settings wider than f5.6.
This is known issue that affect some (apparently quite a few) of these cameras.
My replacement camera also has the issue, although, not as bad as my first.
Cameras that have this issue can watch the vignette shift around with OIS on.
Paul, your camera is probaly VERY close to my current camera.
I'm not sure why Sony is claiming your camera is OK, when we all know there are cameras that do not have this issue at all.
I'd like to know the specfics on how they are making this adjustment.
Old February 21st, 2008, 08:59 AM   #483
Oh. I understood his post to mean that he saw no vignette until he moved the camera.
Old February 21st, 2008, 09:01 AM   #484
I've contacted one of the managers at Sony UK who I met through the video forum in London to find out what he thinks about it. I'll hold out from getting too rattled about it until I've had a chance to talk it through with him first.
My camera only suffers very very slightly with OIS off, and I'm happy with those shots. But I've started using my shoulder rig a lot lately and like to use OIS. If I handle the camera very gently I can get away with it, but any sudden movement brings the darkened corners crashing into the shot.
Watch this space!
Blog: www.pauljoy.com
Paul Joy is offline   Reply With Quote
Old February 21st, 2008, 09:31 AM   #485
Paul,
OIS is usually recommended to be turned off on most cameras when the operator is panning/tilting while on a tripod or movement via steadicam, dolly, etc., due to the OIS fighting the intended movement of the camera operator - which I don't see as as being any different from being rigged on your shoulder unless you are being completely static.
But a problem is a problem and I'd put it back on Sony to fix it.
Just two cents worth - good luck,
Lonnie
Lonnie Bell
mamas boy productions
Las Vegas, NV
Lonnie Bell is offline   Reply With Quote
Old February 21st, 2008, 09:39 AM   #486
Pretty much correct, I can see it with OIS off, but it's so slight that it's not a big problem. With OIS on though, the fact that the effect has motion makes it much more apparent.
Look at this clip, http://www.olikai.com/shake.mov it's a very wobbly shot, way too wobbly to use but you can see the effect on the right side of the frame as the camera wobbles.
Old February 21st, 2008, 10:26 AM   #487
Paul, I'd like to see this same test with the OIS off. Mainly between 8-25mm.
When you say slight, I'm wondering if mine's worse.
Old February 21st, 2008, 11:17 AM   #488
The first frame of that clip is a pretty good indication off how it looks with OIS off as the stabiliser isn't having any effect at that point. All you can see is some slight graduation in the top right corner.
Old February 22nd, 2008, 07:24 AM   #489
Paul,
my apologies...
Here I am chiming in about reducing intentional operator movement with the OIS activated, blah blah blah and then I saw ois-vignette-1.mov:
Don't short change your self, something is amiss with your camera, send it back for a new one.
Lonnie
Lonnie Bell
Las Vegas, NV
Old February 22nd, 2008, 07:39 AM   #490
Yeah, that's pretty awful. I wouldn't accept that either...
Old February 25th, 2008, 03:16 PM   #491
Those of you who sent in their cameras - how long did it take to have it repaired? My camera is away for a week now and I´ve not heard anything about it yet. I´ve sold all my old cameras on ebay and I´m now camera-less...
I called Sony Service today and they did not know anything about the EX1´s status. They did not even know where exactly my camera is! They only know that it arrived last week. I have to say that I´m getting a little impatient now.
thanks and regards,
Gerald
Gerald Loidl is offline   Reply With Quote
Old February 25th, 2008, 03:23 PM   #492
Hi
They had mine 13 days door to door.
Chuck
Chuck Wall is offline   Reply With Quote
Old February 25th, 2008, 03:28 PM   #493
Originally Posted by Chuck Wall View Post
Hi
Chuck
Thanks Chuck!
Wow - thats pretty long!!!
Looks like I will have to rent a camera for the next job :-(
Old February 26th, 2008, 12:29 AM   #494
Did the test today and I find I have some vignetting. Really very slight in top right corner. Mine was bought late but was an early model so should I insist on an exchange from B&H or just let SONY rebuild it? Have there been any modifications made that make it better to try for a current camera?
Michael H. Stevens is offline   Reply With Quote
Old February 26th, 2008, 01:56 AM   #495
Michael,
my camera is a very current camera and still has the same problem...
