Guts at DVinfo.net
Old September 20th, 2007, 09:00 PM   #1
Guts
EX1 vivisection. Click images to see 'em big.
Old September 20th, 2007, 10:02 PM   #2
(Spicoli) "Ohhhhh...GNARLY!!"
Barlow Elton is offline   Reply With Quote
Old September 20th, 2007, 10:10 PM   #3
Funny, that was just on the other night... talk about an actor who's come quite a long way!
Old September 20th, 2007, 10:23 PM   #4
Agreed, but he'll always be Spicoli to me.
Btw, thanks for posting those pics. I love the gory details.
Old September 20th, 2007, 10:59 PM   #5
thanks for posting photos.
Eric Stemen is offline   Reply With Quote
Old September 21st, 2007, 11:10 AM   #6
Absolutely beautiful. I assume that it has an alloy exterior and not plastic? Also on the AV processor photo it says HD to SD conversion. I am confused I thought it would not do SD output.
Old September 21st, 2007, 12:09 PM   #7
If I'm not mistaken, it will do SD output via HD-SDI.
Edit: I should've said "SDI" because the port is switchable between standards.
Old September 21st, 2007, 12:11 PM   #8
There's also a standard def A/V output jack. It's a 10-pin connector supporting S-video output as well.
Old September 21st, 2007, 12:18 PM   #9
I've been wondering...If you select DV as the DR60 drive format, it will record DV *EVEN* when you're actually recording HDV to tape.***
Now - with the DR60 apparently compatible with the EX1's i.LINK (at 25Mbps CBR) - would it also write DV, thus providing the downconvertion some people are missing so much on the new machine?
***Disclaimer: I've never actually tried this; it's what I hear/read somewhere about the DR60 uses with the V1.
