The Ultimate 720p camera. - Page 4 at DVinfo.net
Old October 2nd, 2007, 08:39 PM   #46
Images: 1
Originally Posted by Alexander Ibrahim View Post
I know Discovery will accept DVCPRO HD- but I am unclear on their rules for XDCAM.
Discovery HD accepts the XDCAM HD codec in 35mb for FULL, UNLIMITED program content. HDV is limited to no more than 15% of the content.
Discovery HD WILL NOT accept material from the HVX200. I'm sure it's not the codec, but the fact that sensors are low resolution native, then upsampled to 1280x720. Or, they're put off by 1/3 cameras. But I seem to recall they started accepting the JVC HD cameras which are also 1/3 sensors. The HPX500 also uses a lower native resolution (960x540) that gets doubled to 1920x1080 so I'm not sure how Discovery HD engineers have ruled on that camera. Since you mentioned your interest in the 500, I thought you might want to look into that further.
HDNET uses and owns XDCAM HD cameras.
I have no reason to believe that Discovery HD wouldn't accept the XDCAM EX camera since it has image quality equal to, and in some cases better than the existing full size XDCAM HD cameras.
-gb-
Greg Boston is offline
Old October 2nd, 2007, 08:47 PM   #47
As described in the beloved Wikipedia regarding SDI.
For all serial digital interfaces, the native color encoding is 4:2:2 YCbCr format.
(Dual link could be 4:4:4 but that's another story).
Craig Seeman is offline
Old October 2nd, 2007, 08:55 PM   #48
Images: 1
You beat me to it, Craig. (grin)
I was ready to paste the same section.
-gb-
Old October 2nd, 2007, 09:34 PM   #49
Panoramic
Originally Posted by Greg Boston View Post
Internal media played back through HDSDI = Up conversion to 4:2:2 uncompressed as necessitated by the HDSDI spec.
Why do you think no one knows for sure about this issue? The camera has already been in the hands of reviewers and selected shooters.
But the scenario I described pretty much applies to several cameras, including the current XDCAM HD cameras.
-gb-
I think it unsure because I have read every review and article, post and thread, here and elsewhere, have saved every review and article and no-one has stated such. The tech info provided by Sony does not state specifically, and because, since this camera was announced, I have read as much misinformation and speculation as fact. I need to plan a workflow and equipment purchases with that flow in mind, as do others. Accurate information will help that planning, when it is available.
I am glad that you are clear that the HDSDI spec stipulates that the signal must be 4:2:2 exclusively. That too is the first time I have read that bit of information flatly stated. As I'm not familiar with the HD SDI spec myself, I'm going to do a little digging and confirm for myself, maybe get a further education.
Finally, the EX is an all-new design with a different market niche, so I don't see the relevance to previous models in the XDCam lineup. Historically, new technology means new features and benefits, which means new capabilities, more options. Looking forward to actually using the EX.
Paul Izbicki
i2inewMedia
Paul Izbicki is offline
Old October 2nd, 2007, 09:57 PM   #50
Originally Posted by Paul Izbicki View Post
The quesion is, does playout from the memory cards create an INTERPOLATED 4:2:2 signal??
I think I get what he's getting at.
Short answer: NO.
Once the signal is recorded to the SxS, its 4:2:0- that's it.
It is in fact converted to 4:2:2 for playback over the HD/SDI. This is required by the HD/SDI specification. (SMPTE 292M) Its a bit hard to get the actual spec... as the SMPTE sells it for way too much.
That conversion does not interpolate or otherwise try to display additional information. All of the "extra" information is zeroed out- i.e. it contains no information.
The signal coming out is the same data that you have on the SxS, and a lot of wasted bandwidth. Quality wise it might as well be 4:2:0.
Put differently the HD/SDI link is like a picture frame. You can put a very nice picture in it, or a rather bad one. The frame works the same and doesn't actually alter the picture.
You can get the same result by copying the SxS media to a computer then converting it there to Uncompressed HD 4:2:2.
Just remember- you aren't interpolating or any such. No information is created in this process.
If you need the full 4:2:2 image quality, then the SxS card is useless. You have to record that while the action is happening. You can do that via the HD/SDI link to some sort of outboard recorder.
Does that answer the question properly?
Alexander Ibrahim
http://www.alexanderibrahim.net
Alexander Ibrahim is offline
Old October 2nd, 2007, 10:38 PM   #51
As several of you pointed out in other threads on the XDCAM EX, the difference between the HVX-200 and the PMW EX1 is not simply 4:2:2 vs. 4:2:0. Please check my math and let me know if I have miscalculated.
XDCAM EX has full 1920 x 1080 CMOS sensors.
For 720P it provides full 1280 x 720 = 921600 pixels / frame (and luma samples / frame)
With 4:2:0 chroma subsampling divide by 4 = 230,400 Cb, Cr samples / frame
The HVX 200 has an actual sensor resolution of 960 x 540 = 518400 luma samples / frame ... (960 x 720 if you consider pixel shifting for luma... which doesn't help chroma resolution)
With 4:2:2 chroma subsampling we divide by 2 = 259,200 Cb, Cr samples / frame
So the PMW EX1 ends up with almost twice the luma samples and almost the same chroma per frame.
For 1080i,p the difference is even greater... 4X the luma resolution and 2X the chroma samples per frame. If you capture HD SDI at 4:2:2 you get 4X the chroma samples from the PMW EX1.
I don't have much experience chroma keying... are there other factors in the signal besides the color resolution that affect keying or applying effects?
TV
Tom Vaughan is offline
Old October 2nd, 2007, 10:41 PM   #52
Panoramic
Yes, thanks Alexander, it does.
A shame that. Rather than just filling the 4:2:2 signal with the 4:2:0 source, it would be more useful to convert it to an extrapolated 4:2:2, I should think.
I am primarily concerned with progressive, rather than interlaced. Guess I need to educate myself on what impact that has on the color sampling scheme. I read the Wiki articles on color sampling mentioned in earlier posts, think I'll delve into the DTV Handbook, as their coverage is usually quite expansive.
I guess now I have to do some research on keying and compositing what are essentially 4:2:0 signals. Once captured by an AJA card as HD SDI, would any conversion be required to round trip to AE? Any resources that you could steer me towards would be appreciated.
I was hoping to convert that HD SDI signal into ProRes 422. Still have to figure out how to transfer that into AE for grading, CC, and efx.
Unfortunately, knowing the answere and having a solution are not one and the same thing, but thanks for a thoughtful answer.
Paul Izbicki
i2inewMedia
Old October 2nd, 2007, 11:24 PM   #53
Short answer: NO.
To convert a signal from 4:2:0 to 4:2:2 you have to fill in the missing chroma samples. You can't fill in missing chroma samples with zeros... it would change the chroma signal level from what it should be at this pixel. To fill in the missing chroma you have to calculate the chroma value from the chroma samples in the 4:2:0 signal.
Interpolation (averaging) doesn't mean that you are improving the signal quality... it just means you are filling in the blanks with the best value you can calculate. Essentially you scale up the chroma resolution. Of course this is "empty resolution", not a real increase in resolution.
TV
Old October 2nd, 2007, 11:26 PM   #54
You know, I have yet to actually read anywhere authoritative the actual sensor specifications for the HPX500. Based on he marketing I recieved I thought the HPX 500 was full raster- that's what I get for thinking instead of checking.
Based on the fact that the HPX3000 touts a "full-raster 1920 x 1080" sensor as an "industry first" and your comment I went deeper.
The HPX2000 manual gives its sensor resolution as 1280x720 "valid pixels."
The HPX500 manual doesn't list sensor specifications.
I guess I shouldn't be surprised given that the Varicam is also a 1280x720 sensor. Market differentiation at its very best. (So long as you understand that by "best" I mean "worst.")
It would seem Panasonic has been a bit disingenuous with their marketing materials on the HPX series, which all tout 1080p capability.
Hell, for that matter I can upconvert an XL-1 from its analog outputs- does that make the XL-1 an HD camera? Yeah... didn't think so. If you don't have at least a 1280x720 sensor, you aren't really shooting HD.
Oh, and as to Discovery- I am willing to bet that they won't be accepting HPX500 footage either.
Alexander Ibrahim
Old October 2nd, 2007, 11:29 PM   #55
::snip::
TV
Tom's being more technical than I am, but saying the same thing. If you have to make a decision though use his explanation.
Alexander Ibrahim
Old October 3rd, 2007, 12:00 AM   #56
http://www.dvinfo.net/conf/attachmen...0&d=1159424266
Here is the image I made that I posted a few times on this forum that show the difference between interlaced 4:2:0 and progressive 4:2:0. This image is being used in a magazine somewhere. I don't have the name at all but I was asked permission to use it. 720p on the Ex1 of course uses the progressive method of chroma sampling. The 1080p modes may use it as well but I do not know for sure yet.
To say progressive 4:2:0 is garbage for keying is just plain silly in my opinion. I am a visual effects artist and I love 4:4:4 RGB but I can get some very good results with progressive 4:2:0. Of course I write my own tools to upsample the chroma channels which helps a lot. By up sampling progressive 4:2:0 I can get a very clean but slightly soft 4:4:4 or 4:2:0. It isn't as detailed but it isn't jagged either. in this case about the worse you will get is maybe a slight darker edge around your subjects which can be dealt with.
One of my earlier points was that if quality is such a huge factor for a heavy visual effects shoot I wouldn't use DVCPROHD at all. In fact I would only use uncompressed in such a situation so the recording format doesn't matter at all. For me the cons of DVCPROHD are too much for that critical of footage. If bandwidth and storage were a concern I would at least capture to Cineform and feel confident that I could maintain the level of quality that I need for my sometimes 20 + layers in a composite. In fact if the quality demands of a shoot are really that high I wouldn't even use HDCAM as I think HDCAM is pretty much the DV of HD. I would take a really good 4:2:0 over 3:1:1 anyday.
Thomas Smet is offline
Old October 3rd, 2007, 12:11 AM   #57
Glad I could help
If you are looking for a workflow I have to ask- are you monitoring footage on set?
If so, then do what I plan on: use an AJA ioHD on set to convert the HD/SDI signal from the camera head, which is real 4:2:2 before the XDCAM compression, into ProRes.
If you have to composite the 4:2:0 signal it is doable... in fact depending on your precise needs it can be straightforward. You can definitely do a good key in 4:2:0
I carry on about 4:2:2 and other trivialities- but you have to remember my work is often premiered in theaters. Some detail that you can't see on a 50" plasma looks huge on a 50' screen.
Alexander Ibrahim
Old October 3rd, 2007, 12:11 AM   #58
TV
It can mean better quality depending on how you want to look at it. If you want crisp details then no it will never be the same. Having smoothed out chroma channels will however give you a much better even key then non upsampled chroma. It should be pointed out that if we want to start nit picking chroma so much that 4:2:2 isn't exactly perfect either. It also has to go through a chroma up sampling in the horizontal direction. Progressive 4:2:0 just means it does the same amount of up sampling in the vertical direction as well.
Old October 3rd, 2007, 12:39 AM   #59
Just???
I agree that 4:2:2 isn't perfect, but its a huge difference from 4:2:0 progressive.
Alexander Ibrahim
Old October 3rd, 2007, 07:09 AM   #60
Interesting thread here, but after reading it all I have to say that if utmost quality is needed, then maybe an $8,000 camera is not the correct choice?
If budget is low, then the image quality will have to fall in line.
Tim Polster is offline
