fs5 and FCP 7 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old May 11th, 2018, 07:57 AM   #1
fs5 and FCP 7
just purchased the fs5, (in the post!) having FCP 7 will this edit native ok or is there a work around
thanks
John Doran is offline   Reply With Quote
Old May 12th, 2018, 07:15 AM   #2
Re: fs5 and FCP 7
FCP 7 can't edit native .mxf file. you need to transcode to .mov
Better switch app, may be FCP X or Adobe Premiere.
Rajiv Attingal is offline   Reply With Quote
Old May 30th, 2018, 07:27 PM   #3
Vortex Media
Re: fs5 and FCP 7
Actually, FCP7 can edit some MXF files such as XDCAM MPEG. What it cannot edit is the newer XAVC codecs.
It is long past time to abandon FCP7. Instead of transcoding you should upgrade to FCPX, Premiere, or Resolve. Resolve is free.
Doug Jensen is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
