Sony's New AXS-R7 Recorder Enables 120fps 4K RAW on the F55 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old March 9th, 2016, 12:53 PM   #1
• 4K 120 FPS Continuous High Frame Rate when used with the F55
• 30-second* cache recording before you hit the Record button for capturing spontaneous action
• Robust, all-metal chassis
• Dust- and splash-resistant with environmentally sealed ventilation shaft
• Rigid attachment to the camera with four, widely-spaced 1/4-inch screws
• Dual media slots for operating convenience
• 16-bit linear RAW for unsurpassed dynamic range and color gradation
Existing A Series S24 Card
To facilitate high speed workflows in 4K at 120 FPS RAW recording, Sony's latest AXS memory cards read and write at a sustained 4.8 Gigabits per second. The new AXS-A1TS48 and A512S48 come in capacities of 1 TB and 512 GB.** The AXS-R7 also works with the existing A Series S24 slim cards (blue trim, 1 TB, 512 GB and 256 GB** capacity) recording 4K RAW from 1 to 60 FPS and 2K RAW up to 240 FPS.
Version 8 firmware with XAVC I Class 480 recording & more
The AXS-R7 launch will coincide with F55/F5 firmware upgrade version 8.0 in Summer 2016. To the existing "Class 300" XAVC® 10-bit 422 I frame recording, version 8.0 will add an even more robust, higher bitrate implementation. Introducing XAVC "Class 480", recording for 4K and QHD. Already supported by leading third-party software vendors, Class 480 will be available on the F55 as well as on F5 cameras equipped with the CBKZ-55FX software license. Frame rates include 23.98p, 24.0p (4K only), 25.0p and 29.97p. As we approach the launch date, Sony will be disclosing even more capabilities. So stay tune
Sony's New AXS-R7 Recorder Enables 120fps 4K RAW on the F55-sony_axs-r7_raw_recorder_on_f55.jpg   Sony's New AXS-R7 Recorder Enables 120fps 4K RAW on the F55-sony_axs-r7_raw_recorder_hero.jpg
Sony's New AXS-R7 Recorder Enables 120fps 4K RAW on the F55-sony_new_axs_black_1tb_512gb_media-1-.jpg
Brian Rhodes is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
