Client is supplying S-log scene files - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old July 25th, 2015, 02:20 PM   #16
Re: Client is supplying S-log scene files
Originally Posted by Robin Probyn View Post
So yes engage the P1 (rec709) MLUT for VF and SDI sub..or the LC 709 in the LOOK listing .. but white level is around 70.. use the Zebra/WFM and your eye for exposure
OK. Let me get this straight. Camera is set per their specs on the sheet as I posted, here. Are you saying that peak 100% is going to be at the 70% marking... second bar from the top (or third bar from the bottom) on the WM?
I have zebra set for 70% (facial) and that is just appearing now at that second bar from the top so how can that be peak white?
Plus I'm getting the whites to crush at the top most bar.
"the difference between an amateur photographer and a professional is the amateur shows you all his pictures"
George Odell is offline   Reply With Quote
Old July 25th, 2015, 02:46 PM   #17
Vortex Media
Edit -- changed my mind about posting.
Old July 25th, 2015, 07:51 PM   #18
No not peak level of your WFM.. white level.. REC 709 is 90%.. but the LC 709 .. is a very wide DR LUT.. as in Low contrast in the name..the levels are bought down.. so white is 71% I believe is the exact level..
Skin tone for LC709 is more like 55-60% Rec 709 as you have around 70%.. as a yard stick ..
If the LUT is not being burn in.. and you are shooting purely Slog2.. then I think as "easy" way to get correct exposure,for your under lying Slog2, would be to shoot in P1.. as this is a 1D LUT.. and its the closest the plain vanilla REC mode that we have all be shooting with for years.. if the LUT is to be burnt it.. then of course you will have to work with that LUT in your VF.. and adjust your Zebra for it.. think the F5 WFM is 0/25/50/75/100markings.. its not the best one in the world but gives a quick reference..
Robin Probyn is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
