Internal 4K in F5!? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old August 25th, 2014, 03:02 PM   #1
Internal 4K in F5!?
Could this be for real!?
4K for the F5 | ExtraShot
Per-Axel Gjores is offline   Reply With Quote
Old August 28th, 2014, 03:15 AM   #2
Re: Internal 4K in F5!?
This is real ---------- and it works.
http://extrashot.co.uk/howwedidit/
MI5 or CIA could not have done it better. Now Sony can release a 4k update for F5 without the F55 customers gets furious.
Bo Skelmose is offline   Reply With Quote
Old August 29th, 2014, 08:59 AM   #3
Some users reporting that the dynamic range is reduced when you use this hack. I'm seeing an exposure shift between HD/2K and 4K XAVC in my F5 if I use the hack. Something is not quite right.
Old August 30th, 2014, 01:25 AM   #4
Maybe the Global shutter is activated in 4k - too ;)
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
