Method to control multiple F5/F55 through WiFi? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old February 17th, 2014, 11:15 PM   #1
Is there a method to connect two or more F5/F55 together via WiFi (to share the same setup) or at least simultaneously trigger record start/stop? I'm searching for a simple method to do this for 3D rigs, but it would also be useful for multi-camera shoots.
Tim Dashwood
Old February 24th, 2014, 02:53 AM   #2
Re: Method to control multiple F5/F55 through WiFi?
Hi Tim. At the moment I'm pretty sure it's not possible. You can only connect directly to one camera at a time. Hopefully going forward you'll be able to connect multiple F5/F55's to a network, each with a unique IP and then control multiple cameras as you can with the F65 and the iPad app.
Alister Chapman is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
