The PMW-F55 with the Fujinon Cabrio 19-90 PL servo zoom at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old January 15th, 2013, 06:36 AM   #1
What’s it like to work with?
Nice article by Alister Chapman at XDCam-User.com. A must-read!
The PMW-F55 with the Fujinon Cabrio 19-90 PL servo zoom. What’s it like to work with? |
Cheers!
Henry Epstein is offline   Reply With Quote
Old January 15th, 2013, 07:31 PM   #2
Re: The PMW-F55 with the Fujinon Cabrio 19-90 PL servo zoom
Best part of the article is seeing this: XAVC 1920x1080 50p.
Sony PMW-F55 |
This proves it is possible to shoot 1080p50 and 1080p60 with XAVC. Finally! A proper 1080p60 recording codec!
Old January 16th, 2013, 01:58 AM   #3
You can shoot 4096x2160 60p using XAVC with the F55 and there will be a future firmware update for XAVC 2K on both the F5 and F55.
Old January 16th, 2013, 03:37 PM   #4
Do you have to use SxS PRO+ to shoot 1080p60? Or is that AXS only?
Being AXS only for 1080p60 may not be a good thing as you will need the AXS module to record that framerate. If you can record 1080p60 to SxS PRO+, that'd be ideal. It would put it one step ahead of Panasonic's AVC-Ultra IMHO.
Old January 16th, 2013, 08:03 PM   #5
You can record 1080 60p to SxS Pro+ cards on both cameras. In fact, the cameras only record P. There is no interlaced video.
Ned Soltz is offline   Reply With Quote
Old January 16th, 2013, 09:16 PM   #6
Would be really nice to see this trickle down to the next gen PMW-200 successors. An even sweeter deal would be 3x Global Shutters in either 1/2'' or 2/3''.
Old January 17th, 2013, 02:14 AM   #7
If you put a normal SxS Pro card into the camera, the demo unit I had would record most modes and frame rates on to it. If you tried for example to record 4K XAVC you get a message saying "recording not guaranteed" but it did still record. So for 50/60p HD you will quite possibly be OK with regular SxS cards.
Old January 17th, 2013, 02:52 AM   #8
Have you tried XQD cards with the unit? Any software locks for those types of cards? Cause for 1080p production, that would mean huge cost savings.
Old January 17th, 2013, 03:34 PM   #9
I presume you're only talking about that mode... The Sony specs list 50 & 59.94 interlaced with MPEG2?
Be a shame if this has changed for those doing live TV!
Paul Ream is offline   Reply With Quote
Old January 21st, 2013, 12:06 PM   #10
Sorry for being less than clear. Yes... in MPEG2 HD mode you can record 50/59.94i for broadcast
Old January 21st, 2013, 03:44 PM   #11
I have not tried XQD cards.
Alister Chapman is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
