New PD170 or 2100...audio - Page 2 at DVinfo.net
Old July 3rd, 2007, 07:57 AM   #16
Originally Posted by Jay Voog View Post
Hi Ron,
What is your typical audio setup?
thanks!
Hi Jay
I pretty much described my "typical audio setup" in a couple posts above. See post titled "Azden Cam-3 mic mixer with Sony VX2100"
Ron Priest
Louisville, KY
Ron Priest is offline   Reply With Quote
Old July 3rd, 2007, 08:05 AM   #17
I run auto almost always and make adjustments in post...It is much easier to make adjustments to audio in post. I might check my audio from time to time and slap on headsets every so often to double check, but that is about all I do. Hot is fine, as long as it is not distored, and I find auto keeps it from reaching distortion levels pretty well.
Incidentally, I did add a Rode Videomic to my 2100. amazing. what a difference. I can't believe I waited so long to purchase a shotgun.
Old July 4th, 2007, 09:51 AM   #18
Hi Jeff,
Thanks for your comments...
Just wondering, does it ever seem like the audio is "too hot" when done in auto mode. It doesn't seem to clip, but the audio seems pretty close to distortion at times for me. Lowering the volume doesn't seem to take away the "hotness". When you say you you make adjustments in post, do you mean lowering the volume levels? or what are your adjustments?
Jay
Sony VX2100 cam; FCP 5.0.4
Jay Voog is offline   Reply With Quote
Old July 5th, 2007, 02:37 PM   #19
Of course it does clip at times depending on where you are shooting. If you are shooting in a loud environment (band etc) and if you want perfect you will need to find other options for audio than your cam.
I shoot low and mid priced weddings in volume, and this is not a huge issue for me. I make adjustments during editing to volume and it's fine for my purposes.
I started out criticizing experienced wedding videographer's work in the beginning assuming they didn't care about "getting it right", but now understand that at the price range most of us shoot we cannot afford to do everything the way we might like. Don't get me wrong, I like things to be as perfect as possible, and my customers really like my work. But most of them do not expect pefection, as I have learned not to.
I am however always on the lookout for for new and better ways to do things, as most of us are.
