dead red CCD?
Has anyone ever had a chip die in the VX? I'm guessing that is the problem I have. The cam is not producing any red at all (so it cannot be white balanced). I just became aware of the problem. The camera was fine last time it was used.
I'm wondering if any else has ever had a similar issue and also wondering roughly how much $$$ I may be looking at to get it fixed. -Don |
#2 | |
1.0 prism assy a1- misoperating a-replacement. make what you like of that. chris |
There was a recall on PD170s which fell into a certain range of serial numbers for bad CCDs which were repaired (replaced) by Sony at no charge but I'm not sure if the VX cameras also had this recall.
I would search thru the Sony forum here and see if that recall is listed and if there is a link to Sony which ran the block(s) of serial numbers in question. If not try giving Sony a call I can only give you the Teaneck NJ phone number-1-201-833-5300 HTHs Don |
Thanks for the info guys. Thanks also Don for passing on the NJ number. I'm gonna give them a try right now.
-Don B. |
#5 | |
Steve McDonald https://onedrive.com/?cid=229807ce52dd4fe0 http://www.flickr.com/photos/22121562@N00/ http://www.vimeo.com/user458315/videos |
