Communicating between camera positions at DVinfo.net
Old March 15th, 2003, 06:09 PM   #1
I plan to start shooting event videography. Deciding on the PD150 was the easy part now I need to know about what audio system to use. Leaning towards a senheiser evolution for my lav's.
However, I am hoping to be able to communicate to my other camera persons. Kinda like, "hey get a tight shot of the dad", "am I good to move?", "are you rolling?". Get the picture? Does or has anyone used a good communication system while still listening to audio being recorded by the microphones? And what about using headphones to listen and headphones to communicate?
Thanks in advance,
Mark
Green Novice turning Yellow Pro
Soon to be Ripe - So stand back!
Mark Richman is offline   Reply With Quote
Old March 15th, 2003, 06:25 PM   #2
I cannot tell you what works for me because I don't use radios to communicate with because they tend to interfere with whatever I'm working on. And they are something else to carry/power/fail.
I do know that some of the videographers that bleong to WEVA report good results with headphone style radio communications.
I rely on pre-event assignments for myself and my other camera people. Each are responsible for getting footage of assigned people and events. Everyone also goes for the opportunity shots.
You do have to be careful with radio transmitters around the PD150. If you use them, turn off the steadyshot. Or you wil probably have a jumping picture whenever you key the transmitter.
Mike Rehmus
Old March 15th, 2003, 07:32 PM   #3
Moderator
I have used the RTS wireless system before on some shoots with very good results.
http://www.rts-direct.com/Products_RW.html
Also:
http://www.clearcom.com/products/wireless/wireless.html
This is something you could always rent if you need it only occasionally.
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old March 27th, 2003, 11:47 AM   #4
This sounds like a good idea, but how do you filter out your comments and instructions from the production?
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." -David Letterman
Garret Ambrosio is offline   Reply With Quote
Old March 27th, 2003, 02:20 PM   #5
You cannot. That's why studios only allow the camerapersons to listen, not talk during a take. The person talking has to be certain that whatever they are taping either has the microphone located away from the camera or they shut up.
That said, the way experienced camerapersons communicate is with a puff code. That is they blow gently over the microphone on the radio. A simple morse code can be worked out that will suffice.
Mike Rehmus
Old March 27th, 2003, 02:25 PM   #6
I see your point
guess I better work some signals out for the other cameras.
