Thread Tools
Search this Thread
Premiere Pro HELP!
i need some quick help, i just did my first wedding, everything worked out beautifully, now im exporting it from premiere pro with the adobe mpeg encoder, when i first did it the final product was interlaced even on the tv, if i switch it to progressive when exporting will this solve my problem? i dont have time to manually deinterlace every clip in field options, or is there a faster way to deinterlace all the clips without manually selecting every clip?
any help will be greatly appreciated. thanks -Chris |
#2 | |
What exactly are you seeing happen? Perhaps in your render you should be sure your field order is right ??
Chris J. Barcellos |
i exported DVD format movie and burned it onto a DVD. i played the dvd, and usually the tv converts the footage to be smooth and clear. the tv didnt do this and you can see the little horizontal lines still in the footage. the field order was on upper now im trying it on lower.
Let us know if it works.
#5 |
figured it out, with the adobe mpeg encoder i set the field order to "lower" and my TV figured it out and displays the picture deinterlaced
