Manual Exposure/Shutter Speed - Page 2 at DVinfo.net
Old May 16th, 2006, 12:29 PM   #16
Originally Posted by Aviv Hallale
Is there no way of adjusting the shutter without having to first turn off the exposure button?
No, there is no way. Your shutter speed is selected first, then you manually adjust the aperature. In most situations (except special effects) a shutter speed of 1/60th is all you will ever need, so I don't usually even mess with that. On rare occasions, you might kick speed up, so you can open lense up or properly expose whites in a bright environment.
This shutter speed thing was hard for me to get straight, since I come from a still camera background where you are looking for a higher shutter speed to help reduce damage of camera movement during a shot. That isn't a big issue in video, unless you are going to use captures from the video.
Chris J. Barcellos
