Can't capture in Widescreen? at DVinfo.net
Old April 26th, 2006, 08:04 AM   #1
I filmed a little test in widescreen just to see the quality difference between it and full screen on the VX...On the LCD it looks fine and during capture in a Widescreen Project in Premiere Pro 2 it looks fine, but when I import the clip into my timeline, it's not widescreen. It's displayed as 4:3 but has the black bars on the side. When I select a Standard Project, it just looks like normal 4:3 video....Any ideas?
I think the problem may lie in the fact the first five seconds I captured are in 4:3 and then it goes to widescreen. When I watch the clip in WMP from the beginning, the widescreen part is shown in 4:3 like the beginning of the video,but if I jump directly to that part, it's displayed properly in widescreen.
Aviv Hallale is offline   Reply With Quote
Old April 26th, 2006, 09:54 AM   #2
You need to set the project properties to widescreen.
Laurence Kingston is offline   Reply With Quote
Old April 26th, 2006, 12:16 PM   #3
I did, the video just has black bars on the side.
Old April 26th, 2006, 02:19 PM   #4
Somehow your capture isn't tagging the clips as widescreen. You'll need to change the clip properties so that the aspect ratio is 16:9.
Old April 26th, 2006, 05:38 PM   #5
Sorted, thanks! :D
