VX2000 Blue-Yellow colour shift?? at DVinfo.net
Old March 5th, 2006, 11:17 PM   #1
Hi everyone!
I had my camera out today recording on a ski hill and I discovered something strange on my camera and I'm not sure if it should be doing it...
I just took out and I turned it on, I then looked around with the camera and white balanced it. Then with everything else still in auto mode I set ND filter setting to ND2, looked across the hill and suddenly the picture started shifting blue until all details were dark blue. I tried to white balance it again but it wouldn't balance.
I thought this was the auto mode messing up so aimed the camera at a dark spot on the hill and manually set the f-stop to 8 and shutter to 1/250. I re-white balanced and everything was great for the rest of the day I left the shutter at 1/250 and adjusted the f-stop between F6.8 and F8.
Tonight I was reviewing footage and wanted to look into what was going on. The blue shift appeared on the tape when I played it back and I noted that when it started to shift blue, the shutter was jumping up to 1/1000 or higher.
I decided to investigate the problem:
First I resetted the camera.
Now setting everything in manual mode, I decided to check it out.
Setting it to F3.4 and shutter to 1/60 I white balance it.
If I increase the shutter to 1/250 or higher the picture picks up a blue tint until I get to 1/10000 when it is all blue.
If I set the shutter to 1/500 and white balance it everything looks fine, now if I lower the shutter to 1/250 or lower the picture picks up a yellow-green tint and I have to re-balance the colours.
Setting the shutter to anything above 1/1000 and manual white balance won't work, it just flashes and stays blue tinted.
My camera VX2000 is around 3 years old I think.
One more thing I just discovered, if I turn on "Demo Mode" then hit the "menu" button the picture goes completely blue and then fades back to normal (within 1 second). If I press the menu button again the picture turned completely yellow then fades back to normal (within 1 second). So opening menu, background fades yellow, closing menu, background fades blue. It only does that when it is set in demo mode (I discovered this by accident, because when I reset the camera it turned on demo mode)
What is going on here?
Is this anything similar to the problem that sony addresses in this message? (link below)
http://esupport.sony.com/perl/news-i...000&news_id=95
or what is going on in this thread?
(link below)
http://www.dvinfo.net/conf/showthread.php?t=36612
Sean Bouchard is offline   Reply With Quote
Old March 13th, 2006, 11:25 AM   #2
HI Sean Bouchard,
I think one of your CCD just blew off... I had the same problem on my Vx2k and it was just two months old so I colud make repair cause I still had warranty on it..
ciao..!!!
Sony VX2K Nizo S800
Alex Anzalone is offline   Reply With Quote
Old March 13th, 2006, 02:53 PM   #3
I just got a call from the shop. All CCD's are being replaced by Sony free of charge! Woohoo! The issue was determined to fall under that problem that I posted the link to.
