AUDIO SETUP for NEWBIE at DVinfo.net
Old January 20th, 2003, 01:32 PM   #1
Zack Depagbilao
Posts: n/a
help guys....
i got some Q's
1. which is better BEACHTEK with or without PHANTOM
POWER?? (ill be using AZDEN SGM2X)
2. what is the use of BEACHTEK w/ PHANTOM POWER if
your shotgun is battery powered??
3. how can i connect a shot gun (XLR) & a wireless lav
(mini) to the beachtek at the same time, my problem is
the wireless system has mini plug while the beachtek has
a 2 XLR inputs, will buying a mini-to-XLR adapter will solve this??
4. which is better a mic powered by battery or phantom powered?
THANK YOU GUYS
Old January 21st, 2003, 08:39 PM   #2
I'd look for an adapter that allowed either XLR or mini inputs. There are some out there.
Phantom power often gives the microphone better performance as compared to a 1.5 VDC battery supply. You have to evaluate the specs on your microphone to tell.
Having a Phantom power option is always better. You just have more options for microphones.
Mike Rehmus
Old January 22nd, 2003, 09:25 AM   #3
Zack Depagbilao
Posts: n/a
THANXX MIKE that helps a lot
