Watts On NP-F970? at DVinfo.net
Old January 11th, 2006, 10:46 PM   #1
Watts On NP-F970?
Hello.
How many watts is a NP-F70 sony battery?
If someone has this battery could they please check. It is written on the battery most of the time.
Richard Zlamany is offline   Reply With Quote
Old January 12th, 2006, 12:20 AM   #2
it reads 47.5Wh
Kawai Sin
www.rollingedit.com
Kawai Sin is offline   Reply With Quote
Old January 12th, 2006, 12:31 AM   #3
Don't forget that if you put a heavy load on a battery and drain it at it's specified rating that it will have lesser output. Batteries are rated for a slower rate of drain. I know, it's stupid. I didn't make up the rules.
If you have a 47W light on a 47Whour battery, it will die in less than an hour.
Old January 12th, 2006, 12:43 AM   #4
Thanks for answering.
I have a strange problem. I bought a new sony NP-F970 but when I plug it into the sony 10/20 watt light it goes out in 5 minutes. It is fully charged and works in the camera as usual but not the light. When I try another battery the light works fine. The battery is fine in all regards save the light.
Flicking the switch on the light powers it up for another 5 minutes.
I wonder why this would happen. It looks like a genuine Sony battery but I did buy it off of ebay.
It only happens when I use the light in the 20 watt mode. In the 10 watt mode the light works.
Old January 12th, 2006, 07:52 PM   #5
Go Cycle
There is a chip within the battery that causes the battery to appear to drain if overheated. Next time, take the battery out of the light and let it cool down.
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old January 12th, 2006, 08:40 PM   #6
yes, in the cabling between the cell, there is a kind of thermal fuse.
since in 20w mode you are trying to get half of current and in 10W mode, only a quarter, it seems the battery is designed to drain between these 2 values. (around 12-15W).
do not forget that these high capacity batteries are supposed to power a camera for several hours.
Old January 12th, 2006, 09:22 PM   #7
Interesting.
The battery is not hot but warm. When it is warm it lasts for 10 seconds.
When I use a non sony NP-F970 battery it lasts for hours and gets hot without turning off.
What battery am I suppose to use with the Sony 10/20 watt sony light. The sony should last more than 5 minutes.
Ironically the non Sony NP-F970 battery works for hours without a hitch and cost less than the sony which works for 5 minutes.
Shouldn't the Sony battery work better than the non Sony battery?
Does anyone use the Sony NP-F970 with Sony 10/20 light with success?
Sorry this may be in the wrong forum but the light is for a pd170 as are the batteries
Old January 12th, 2006, 11:04 PM   #8
Be careful of non-Sony batteries exploding.
Kawai Sin
www.rollingedit.com
Old January 13th, 2006, 10:21 PM   #9
I am taking the chance, since the non sony batteries operate the light longer than 5 minutes. What other choice do I have save to buy a new light.
Old January 14th, 2006, 10:20 AM   #10
Fred Retread
A battery rating of 47.5 watthours does not mean the NP-F970 can deliver 47.5 watts for an hour. And a rating of a Sears Diehard battery of 230 Amphours does not mean it can deliver 230 amps for an hour. These ratings really indicate how much charge the battery can store. The power at which they can deliver it is a matter of fairly involved chemistry and physics. Camcorder batteries, especially infolithium batteries also contain electronic controls that complicate the picture further.
The NP-F970 stores enough charge to power your 20W light for several hours, but is not designed to do so. It is designed to power a cam for up to 18 hours. That's more like 2 to 3 watts. If you ask it to power a 10 watt device, you're pushing it. No suprise that it cuts off quickly at 20 watts.
To get the best battery for your light, I'd go to one of the big online battery suppliers with obvious names like batteries.com, and maybe give them a call.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old January 14th, 2006, 12:56 PM   #11
Thanks Fred. That clears it it up.
Old January 21st, 2006, 09:19 PM   #12
An update:
I bought the battery from carolgift on ebay. It didn't work with my light. So I decided to use with my camera at a reception today.
In the middle of the chicken dance song (there was a lot of children) the battery died even though 270 min remained seconds before its death.
A bad, new, genuine sony, ebay bought battery is the cause of this thread.
Old January 30th, 2006, 08:00 AM   #13
Just to give some info on video camera batteries...
The Li-ion battery packs use a very complicated managment chip inside the pack. This chip checks everything from current draw, remaining power and measures the voltage of EACH cell inside the pack.
The reason that there is a management chip is to protect the cells (and yourself) from damage. Li-ion cells must not be discharged below 2.8 volts (per cell) or they will lose capacity. Also the chip prevents the cell from being shorted (due to improper use, or battery damage) leading to overheating and possibility exploding.
Li-ion batteries have a very high internal resistance meaning that when you draw a lot of current from them (such as video lights) the cells see a large voltage drop across them. If any one of the cells inside the battery pack are unmatched (cells are matched at the factory) or have lost capacity due to manufacturing defect, age, etc... the management chip will detect the sudden drop in voltage (across a cell) and turn off the battery pack.
This is what you are seeing with that battery and the light. Basically the only thing you can do to try and get the battery to work properly is leave it on the charger for atleast 12 hours.
If the battery shuts off on you when you are using it on the camera with that much "estimated" time left, then there is something fishy going on with it, I would guess a bad cell. Li-ion batteries normally have a very linear discharge rate.
anyway I hope that wasn't too much info (I've done a lot of research on li-ion technoogy)
Sean Bouchard is offline   Reply With Quote
Old January 30th, 2006, 06:34 PM   #14
Thanks. Your post was helpful.
