Mic for the PD-170?
Hello,
I am looking for a good all purpose mic for onboard event work for my PD-170. I own a good shotgun but would like to have an omni or cardiod for general use. After talking to Sony support, I was told to get a mic with an output of -60db to -40db to avoid overloading the pre-amps. (the stock mic being -55db) Sony support also recommended a dynamic mic to handle loud situations like a wedding reception. Any thoughts? I am hesitant to use a dynamic since so many that I have used sound best in a close micing situation. SM81?? Thanks |
Nevermind, I have found a solution.
what was the solution?
I too am interested in what you chose to get.
Matt Trubac |
#5 |
I've read a lot of good recommendations on this board. Though I rarely see the Audio Technica AT822 stereo microphone mentioned, likely due to its price. It was recommended by an audio technician at a music store, and I think I bought a slightly used model. I just LOVE this
microphone. The stereo field, sound, and lack of hiss is sooo much better than the on-board Sony VX2000 microphone. It overloads a bit in automatic mode (with AGC), but I don't have such problems in manual audio mode. It's not a dynamic mic, so it needs a AA battery. I use Energizer 2500 mAh rechargeables. http://www.bhphotovideo.com/bnh/cont...ughType=search I use this microphone to record martial arts unarmed and stick fighting, and it handles loud wood on wood strikes very well. While it can be used for weddings, I wouldn't recommend it due to its wide response pattern. It's great for picking up ambient crowd noise, though. |
#6 |
Can the at822 be turned into a wireless mic with a butt-plug?
#7 | |
Martin at HeadSpin HD on Blu-ray |
#8 |
Hey,
I decided to use a Peluso condeser mic I own with a 10 or 20 db pad switch. The mic has a switchable capsule for cardioid or omni. After speaking with the mic manufacturer, I was told the pad does not effect the sound quality outside of a slight S/N ratio change. |
