Wide Angle Adapter - Page 5 at DVinfo.net
Old January 9th, 2003, 08:41 AM   #61
just a question a little off topic... but i recently purchased a century optics 65 WA adapter and became a little conserned after reading a few posts up about defected lenses.
what defects were these?
are there any tests i can run on my WA adapter to see if its ok?
i have a shoot scheduled in two days. first time out with my pd150 and new accessories. i want to bring unexpted problems to a minimum, expecially if it has to to with camera equipment.
thanks.
Adi Head is offline   Reply With Quote
Old January 9th, 2003, 03:03 PM   #62
I am inclined to go with the Kenko now if it is "just as good" and half the price.
Mark Thomas is offline   Reply With Quote
Old January 13th, 2003, 03:38 PM   #63
no, no, I just cancelled the Kenko one after some bad reviews.
What about the Raynox 66x? is that better? Maybe I should order all three and send the others back.
Old January 15th, 2003, 08:30 AM   #64
in what way can a wide angle adapter be defected?
Old January 22nd, 2003, 03:14 PM   #65
Re: wide angle adaptor
<<<-- Originally posted by Adi Head : i just bought a century optics 0.65x and a B+W UV filter for my pd150.
i guess this may be a silly question, but after trying i can't help but come to the conclusion that in order to fit on the WA adaptor, i have to first remove the UV filter which is usually screwed on to protect the camera lense. is this true? i didn't want to try too hard to place the WA adaptor on top of the filter, for fear of scratching the filter. -->>>
I just received the Raynox 65x lense which I am happy with. See nothing wrong with it. I screwed it right on over my uv filter and the pressure cracked the filter. So I will make sure to take all filters off of the camera before mounting a lense.
Old February 26th, 2003, 01:14 PM   #66
Guest
Posts: n/a
Wide Angel Conversion Lens
I have Century Wide Angel Conversion lens, the same one as Mike's. I go shoot video and I get a lot of vending effect where the thing on the top edge of the video looks big, and things in the middle is small. So if I shoot a person, and framed such that head is near the top of the frame, then the subject's head is SO MUCH larger than body, it looks like a marsian.
Is there a way to avoid this, but still be able to stand closer to the subject.
Old February 26th, 2003, 04:02 PM   #67
I use the WD-58 not the Century but from reading pasts posts here the Century did not seem to distort the image any and as far as i know its a full zoom thru lens (.65).
If its a screw on mount be sure that it is threaded properly and i would screw it directly on the lens and not stacked on top say a UV filter etc.
Matt Stahley is offline   Reply With Quote
Old February 26th, 2003, 04:34 PM   #68
Guest
Posts: n/a
Thank you,
Yes, it's screwed right on the lens with bayonet mount. I checks just before I start shoot everytime. Is it because I am standing from the arm length away from the talent trying to get wast up body shot? If so, is there any lens that does let me tape it without distoriton.
Old February 26th, 2003, 05:39 PM   #69
Anne,
perspective distortion with a WA or fisheye lens can be hard to get around. With a WA lens the closer you get to you subject the more distortion and more out of perspective the subject will look. Try this; with the lens on and the cam on a tripod, get in really close to an object. Focus on the near point of the object and then look at the perspective, then move back a foot or two and focus in on it again. You'll probably see less perspective distortion but you're shot will have changed so try a little zoom for framing. Generally with a WA lens have to back off just a little so as not to have the distortion.
Hope this helps,
Don
Old February 26th, 2003, 07:35 PM   #70
This may be an impertenant question but if you are shooting with a WA lens why are you so close to the object or person that you are taping? Wide angle and particularly fisheys lens are used to create 'artistic' distortion close up. If you are close why not just take the lens off? Or am I missing something?
Rick Spilman is offline   Reply With Quote
Old March 8th, 2003, 03:27 PM   #71
Guest
Posts: n/a
I use WA so that even when I am standing up against the stage, I will stil be able to frame wide enough to get a shot that has knee up to the head of the subject. Isn't that what WA supposed to do though?
Old March 8th, 2003, 03:47 PM   #72
If you are close enough with a wide enough angle lens you will get distortion. The distortion can be fine if that is what you are going for. Otherwise take off the adapter and go for the close up or move back from the subject.
Old March 8th, 2003, 09:59 PM   #73
<<<-- Originally posted by RagadyAnne : I use WA so that even when I am standing up against the stage, I will stil be able to frame wide enough to get a shot that has knee up to the head of the subject. Isn't that what WA supposed to do though? -->>>
"Standing at the edge of the stage"??? Does this mean you are standing in the audience below stage level looking up at your subject? If so, yes, any wide angle lens will distort from this angle. You see it very often in rock concerts on television.
If you are standing eye to eye with your subject at arms length, and getting distortion, try zooming in a bit. It should help eliminate some of the distortion. Also be aware to hold your camera as level as possible to help eliminate the "parallax" effect with the wide lens.
Wayne
If it was easy, they'd get a relative to do it.
Wayne Orr is offline   Reply With Quote
Old March 9th, 2003, 07:58 PM   #74
Guest
Posts: n/a
Does the footage I did last night looks distorted? I shot 2 song without WA. The following footage is how the thing looks. I followed advice, first forcused on how I want frame, the stepped back 2 feet then reframed it. the result looks like this:
http://207.44.160.90/~admin8/testmedia/testfile.wmv
Thanks for advice.
Old March 25th, 2003, 11:21 PM   #75
Wide Angle Lens Sony vs. Canon
Which lens do you think is better the Canon wide angel or the Sony
wide angel? Is there a third choice?
Why ask me? I thought you were in charge!
Joe Gioielli is offline   Reply
