Wide Angle Adapter - Page 19 at DVinfo.net
Old July 13th, 2004, 07:03 PM   #271
I have the exact same lens and I noticed that when I zoom all the way to the end the picture gets slightly soft and little color distorted. When I lower the zoom the picture is as mentioned above wonderful. Is this a defect in my camera lens of am I zooming to far out? I was very interested in hearing how well the lens performed for others but am concerned I am not getting the same results with my 2100. Any input is welcomed.
Gabriel Selmi is offline   Reply With Quote
Old July 15th, 2004, 12:39 PM   #272
About $300.
Dave Largent is offline   Reply With Quote
Old July 24th, 2004, 07:43 PM   #273
Sony Wide Angle View
I have a Sony VCL-HG0758 58mm 0.7x High Grade Wide Angle lens attached to my VX-2100. I notice that when I zoom all the way to the end the picture gets slightly soft and little color distorted. When I lower the zoom the picture clears and returns to normal focus. I have done several experimements using all the manual controls available with the same resilts. Has anyone noticed the same symtoms or is this a defect in the wide able lens of zooming to far in? Without the wide angle lens the camera funtions and records very good. Any input is welcomed.
Old July 24th, 2004, 08:29 PM   #274
Re: Sony Wide Angle View
<<<-- Originally posted by Gabriel Selmi : I have a Sony VCL-HG0758 58mm 0.7x High Grade Wide Angle lens attached to my VX-2100. I notice that when I zoom all the way to the end the picture gets slightly soft and little color distorted. When I lower the zoom the picture clears and returns to normal focus. I have done several experimements using all the manual controls available with the same resilts. Has anyone noticed the same symtoms or is this a defect in the wide able lens of zooming to far in? Without the wide angle lens the camera funtions and records very good. Any input is welcomed. -->>>
Most wide angles and fisheyes get "soft" or even completely blurred when zoomed in to a certain point.
I've noticed too that it depends on the camera.
I've seen the same lens act differently on different cameras.
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Ray Echevers is offline   Reply With Quote
Old July 25th, 2004, 12:40 AM   #275
I think the point to bear in mind Gabriel is that you've bought a wide-angle converter for increasing your wide-angle coverage. If you can use it at other focal lengths that's a bonus, but I haven't found one yet (regardless of price) that doesn't degrade the image slightly. If you want to shoot at 30mm it's better to take the w/a converter off (though of course more hassle).
tom.
Old July 25th, 2004, 05:17 AM   #276
Thanks for the replies, I am more comfortable knowing these results are somewhat consistant. Could I have got something other than a convertor that would produce better results?
Old July 25th, 2004, 10:40 AM   #277
Unfortunately, only a pro camera with removable lenses. Then the very wide angle pro zoom lens can cost more than $25,000.
Mike Rehmus
Old September 21st, 2004, 02:20 AM   #278
VX2000 loss of sharpness with wide converter
I find the widest angle of the VX2K to be insufficient for a lot of work so I've started using a Canon 0.7x wide converter with it.
Despite keeping everything nice and clean I'm noticing a lack of sharpness, particularly in subjects more than a few metres away. In fact it's such that I'm even considering using my old Panasonic DX100 for some shots as that has a wider angle than the VX2K without the lens. But I'd rather not!
Is this loss of sharpness to be expected? Is there anything I can do about it?
Nick Hope is offline   Reply With Quote
Old September 21st, 2004, 09:44 AM   #279
My Century does the same. I sent it back to them for evaluation. They said it is normal.
I use it only sparringly because of that.
Mike Rehmus
Old September 21st, 2004, 03:02 PM   #280
Yeah, I noticed the same with my Canon 0.7x wide angle converter, which I bought after my Raynox 0.66x exhibited the same. The Raynox is pretty nice, but really goes soft when the VX2000 is at maximum zoom, regardless of focus. I've been experimenting with underexposure
by using f/stops around f/4 for my particular available light. I do not know what is the sharpest f-stop over the zoom range. Using a smaller aperture seems to yield better clarity with the Canon wide angle, although I have not quantified the results.
Both Mike and I were involved in another thread that's somewhat related :
VX2000 : best lens sharpness aperture?
http://www.dvinfo.net/conf/showthread.php?s=&threadid=32105
Gints Klimanis is offline   Reply With Quote
Old September 21st, 2004, 04:42 PM   #281
In general, any auxiliary lens is going to negatively affect the image quality. Most aux lens are formulated to a general spec and not for a specific camera & lens combo. So they won't be as good as they can be and almost never as good as a prime lens at the same magnification.
Mike Rehmus
Old September 22nd, 2004, 08:53 AM   #282
Mike's right in that there's no free lunch. But my tests of the Century 0.65 bayonet and the Raynox 6600 PRO show them to be staggeringly close to the camera when used without them.
I set up the VX on a sturdy tripod and filmed perpendicular to a brick wall, sending the images to Memorystick. I used lots of different apertures and recorded all the results. I then attached the wide-angles and zoomed up so that the camera's view was the same. I then imported these images into Photoshop for a good A/B look-see.
This is an excellent test to find out what adding 3 extra elements to the Sony's line-up does for resolution, contrast, colour balance, vignetting and distortion. I was impressed by how subtle and small the changes were. Better to use slightly smaller apertures like f5.6 and 8 when you have the converter on I find.
Zoom to full wide with the converter on does harm chromatic aberations, but in general the sharpness holds up well, and I've been slightly surprised by the words I read above.
tom.
Old September 22nd, 2004, 09:03 AM   #283
I found the Century 0.65 bayonet to be such a disappointment that I sent it back to Century for a quality check. I t performed similarly on both of my PD150's . . . such a noticable softening that I don't like to intercut footage from the same camera with and without the adapter. Century said it works normally.
I find it softens the image by an unacceptable amount and I only use it when I must.
Mike Rehmus
Old September 22nd, 2004, 02:15 PM   #284
Thanks, Tom. I noticed a big gain in sharpness when opening to f/4. In the future, I'll try the settings you list above.
Old September 24th, 2004, 03:13 AM   #285
I had canon xm2 with canon 0,7x wide lens and didn't notice EVER lose of sharpness and resolutino on any disortion using wide lens attached in any situatin either using wide or tele. Now I've got PD-170 with this sony 0,7x lens (comes as a bundle) and must say that this is very irritating disortions and lose of sharpness using tele. It means that guys from sony must lern a lot about engineer a really good lens in their camera. It's not about the wide lens You have attached but about the original lens You have got in Your camera PD-170 or VX2100. It just can't work well with wide conversion lenses. Saying that: "You've got wide conversion lens to do wide shots" is really stupid - imagine taking it off every single time when you want do do some details close ups to achieve good quality picture. :)
Always Unhappy?
Jakub Pankowski is offline   Reply
