Extra shoe VX-2100 at DVinfo.net
Old May 13th, 2005, 01:11 PM   #1
Extra shoe VX-2100
I have a HVL-S3D video light that uses the VX-2100 hot shoe for power. I also have a shotgun mic. I want to use both, I've seen dual shoe adapters but none are hot. Any info where I can get one?
Frank Yap is offline   Reply With Quote
Old May 13th, 2005, 01:13 PM   #2
does the mic use power from the shoe itself??
Matt Stahley is offline   Reply With Quote
Old May 13th, 2005, 01:20 PM   #3
You might want to be a bit careful how much power you attempt to haul through the hot shoe. I don't know if Sony states any limits but you might want to touch base with them before you attempt that, assuming you can find a y connector in the first place.
Mike Rehmus
Old May 13th, 2005, 02:42 PM   #4
The mic doesn't use any power from the shoe.
Old May 13th, 2005, 09:33 PM   #5
Frank take a look at the mini rover from videosmith it will give you an extra shoe mount off the side of the cam along with a nice hand grip for more stability in hand held shots leaving the actual hot shoe for the light. I personally dont own one but have only heard positive things.
Old May 14th, 2005, 07:36 AM   #6
Thanks Matt, that would be a solution. I've been searching google all week but didn't hit Videosmith.
Old May 14th, 2005, 10:02 AM   #7
here is link to product at B&H. Mini-Rover
