iris on vx2100 at DVinfo.net
Old May 8th, 2005, 09:20 PM   #1
iris on vx2100
Hello
All the time i hear about iris and settings, but if i check manual book how to set manual iris on vx2100, does not say any word about that?! Or which exactly bottom it's on the cam
thanks
Andzei Matsukevits is offline   Reply With Quote
Old May 8th, 2005, 09:56 PM   #2
In order to change Iris settings on your 2100; switch the back switch to the middle choice, manual (right under auto). Then press the exposure button on the left side of the cam and use the dial beside it to change your video gain/iris.
As you move it down you're iris will go up. It's measured in f stops, for instance F 2.6 or something.
Page 45 in your manual. It's under exposure.
Advil Dremali is offline   Reply With Quote
Old May 9th, 2005, 06:39 PM   #3
thanks Advil!
Old May 10th, 2005, 09:11 PM   #4
Anytime. If you need help you can email me: Kvasir@gmail.com
or talk to me on msn or aim. If you need that info just email me.
