Sony VCL-HGA07 HD 0.7x Wide Angle Converter Lens on DCR-TRV19 at DVinfo.net
Old September 25th, 2009, 07:51 AM   #1
Hi,
I know this is not related to Sony VX2100 / PD170 / PDX10 but my question is related to a Standard Definition (DV) so that's why I post here.
My question is can I use a "Certified High Definition Quality" - Sony VCL-HGA07 HD 0.7x Wide Angle Converter Lens on my DCR-TRV19 and shoot in 4:3 or emulated 16:9 ?
I currently use SIMA SLS-20 0.5x with "worth the money" result but would like to upgrade on the wide angle image quality. And I'll be able to reuse it once I move up to HDV camcorder later.
Any comment is appreicated.
B.R.
Calvin
Calvin Chang is offline   Reply With Quote
Old September 26th, 2009, 02:53 PM   #2
if the lens fits the threads (I presume it will since 37mm is pretty standard Sony threading), yep it will work fine, and should be a superior lens with better results than a cheaper lens.
Old September 26th, 2009, 09:46 PM   #3
Hi, Dave:
Thanks for your comment. I'm now feel safer to order it. BTW, for the record, the correct model# is SIMA SLS-05 0.5x, the SIMA SLS-20 is actually a 2.0x telescope which I don't own.
B.R.
Calvin
