Hot Shoe Question on VX2100 at DVinfo.net
Old January 3rd, 2005, 06:55 AM   #1
I'm getting ready to get a HVL-20DW2 light for one of my backup cams (VX2100)...Since the 2100 has a hot shoe, can I safely mount the light or do I have to isolate the mount with tape or some other material...
Mark A. Foley is offline   Reply With Quote
Old January 3rd, 2005, 08:06 AM   #2
I use that light in the hotshoe of my PD170 with no problems. It fits firmly in the shoe.
Allen Brodsky is offline   Reply With Quote
Old January 3rd, 2005, 08:11 AM   #3
Actually the shoe on the 170 is a cold shoe....
Old January 3rd, 2005, 08:37 AM   #4
oops
Oops, you're right. However, the light fits firmly in my TRV-900's hotshoe (as well as in the 170 cold shoe), using the light's mounting screw to tighten it against the shoe bracket. I would expect it to fit fine in the VX2100, but I have not used the light with that cam.
Old January 3rd, 2005, 08:41 AM   #5
My only concern...and may not be an issue at all...is the voltage present at the shoe and what happens when a unit in placed in there that is not designed to pull voltage
Old January 3rd, 2005, 08:56 AM   #6
Mark,
The hotshoe on the TRV-900 has a spring-loaded cover over the metal contacts. This cover does not retract when the Sony light slides into the shoe, so there's no voltage effect on the cam one way or the other. Also, the foot on the HVL-20DW2 is plastic anyway.
Old January 3rd, 2005, 09:03 AM   #7
Duh...I should have remembered that...I have another one that is actually mounted to a metal/adjustable mount....so bieing plastic, it is not an issue at all :-)
Thanks..........
Old January 5th, 2005, 09:59 AM   #8
And while we're talking about that little light, some tips.
Always use it in ther twin lamp mode as this softens the shadows very effectively. Rather than having a point source of light, you've almost got a 2" x 1" light source.
Next, well worth getting a Lumiquest Mini Softbox. it velcros quickly into place, absorbs a stop, but at the same time softens the light yet again, and makes you much more popular ar parties and wedding receptions.
tom.
Old January 5th, 2005, 11:49 AM   #9
Or you can just buy a sheet of diffusing gel and tape a bit across the lens of the lamp. Much less expensive and easier to manage. than a softbox. You can get different levels of diffusion so you can fine-tune the effect.
This is what the ENG camera operators do all the time.
Mike Rehmus
Old January 5th, 2005, 12:18 PM   #10
Good advice, Tom and Mike. I use Rosco "tough white diffusion" (#3026) gel. The Sony light is a good value and, since it uses Sony batteries, easier to manage than more expensive camera-mounted lights. Using gels or the mini softbox provides almost as much light control, too.
