Using 1/8 to XLR adapter w/PD170 at DVinfo.net
Old December 13th, 2004, 01:46 PM   #1
Has anyone had problems/success using the on camera mic with a second mic (lav mic/receiver with 1/8 stereo mini to XLR)? I am trying to use my Audio-Technica Wireless Lav with my PD170, but am not getting any input signal. I am using an adapter cord I purchased from BH Photo (1/8 stereo to XLR Male), and I have checked that all cords/inputs/outputs are working fine.
I found that I can get signal if I plug the adapter into the headphone out of the receiver, but the signal is way too hot/distorted. If I come off the mic output, I get nothing. Can anyone help out here? Thanks.
Choose your attitude...Be Positive!
Frank Pietrantoni is offline   Reply With Quote
Old December 13th, 2004, 02:07 PM   #2
Re: Using 1/8 to XLR adapter w/PD170
<<<-- Originally posted by Frank Pietrantoni : Has anyone had problems/success using the on camera mic with a second mic (lav mic/receiver with 1/8 stereo mini to XLR)? I am trying to use my Audio-Technica Wireless Lav with my PD170, but am not getting any input signal. I am using an adapter cord I purchased from BH Photo (1/8 stereo to XLR Male), and I have checked that all cords/inputs/outputs are working fine.
Something isn't set correctly or the cable is not wired for your setup.
I found that I can get signal if I plug the adapter into the headphone out of the receiver, but the signal is way too hot/distorted. If I come off the mic output, I get nothing. Can anyone help out here? Thanks. -->>>
Do you have the XLR input set up for microphone with the attenuator turned off?
Mike Rehmus
Old December 13th, 2004, 02:53 PM   #3
Re: Re: Using 1/8 to XLR adapter w/PD170
Yes I've tried all settings to no avail. Do you know if there is specific adapter to use for this aplication? I assumed that the 1/8" to XLR from BH Photo would have done the trick.
Old December 13th, 2004, 03:52 PM   #4
It still sounds like a level mismatch or a wiring error.
If B&H said it would work, then I'd expect it to be wired correctly.
If you set the XLR input for Line and then feed in the earphone output, does that approximate a reasonable signal?
Mike Rehmus
Old December 13th, 2004, 06:49 PM   #5
<<<-- Originally posted by Mike Rehmus : It still sounds like a level mismatch or a wiring error.
If you set the XLR input for Line and then feed in the earphone output, does that approximate a reasonable signal? -->>>
Well...B&H didn't actually say this would work for this application, but I assumed it would (my mistake I guess). I tried setting input to Line but the signal is still too hot.
Maybe there's a different type of mini to XLR adapter that I need. I know that Sony's wireless lav system (UWPC1) uses what they call a 3-pole mini to XLR cable. But I haven't been able to locate that exact spec.
Old December 14th, 2004, 12:10 PM   #6
I'll Try Something else...
I found that Audio-Technica makes a mini to XLR Line Matching Transformer/Cable for this purpose. I'l give that a try.
Old December 17th, 2004, 07:51 PM   #7
Re: I'll Try Something else...
<<<-- Originally posted by Frank Pietrantoni : I found that Audio-Technica makes a mini to XLR Line Matching Transformer/Cable for this purpose. I'l give that a try. -->>>
In case anyone was wondering, the Audio-Technica Cable solved my problem.
Old December 17th, 2004, 08:19 PM   #8
Great
Mike Rehmus
Old December 17th, 2004, 11:09 PM   #9
Re: Re: I'll Try Something else...
<<<-- Originally posted by Frank Pietrantoni : <<<-- Originally posted by Frank Pietrantoni : I found that Audio-Technica makes a mini to XLR Line Matching Transformer/Cable for this purpose. I'l give that a try. -->>>
>>I think the original problem was caused by you thinking the cable was a one inch stereo mini. Just because a mini has three conductors doesn't mean its stereo.
It's just a cable. It could be stereo. It could be mono. It depends on what it's plugged into on each end and the way in which the cable is configured.
A USUAL female XLR to mini TRS is NOT a stereo cable. It's a balanced mono cable. If the female XLR is wired with pin #2 connected to BOTH the tip and ring of the mini TRS, now you have a cable that allows a mono mic to be plugged into a stereo unbalanced camera input.
There are a lot of tips like this in the "Audio Bootcamp Field Guide", which makes a nice stocking stuffer, btw. ;)
Regards,
Ty Ford
Ty Ford is offline   Reply
