Progressive Scan on VX2000?? HELP at DVinfo.net
Old August 27th, 2002, 11:59 AM   #1
Drew Craig
Posts: n/a
Help.
Is there any way around the 12.5frames/sec progressive scan mode? I know the Canon GL1 can shoot in "Frame Mode"- 24frames/sec..and the result looks very filmic.
Any way to use Progressive Scan to get similar results (a better film look)?
Drew
Old August 27th, 2002, 12:46 PM   #2
The camera only runs at the factory setting.
The GL1 will operate at 30 pfs in frame mode. It does not run at 24 fps.
Mike Rehmus
Old August 27th, 2002, 01:21 PM   #3
drop the camera down to 1/30 shutter speed (1/25 PAL).
this gives you more of a "filmy look".
you may have to add a ND filter to the lens itself to prevent over exposure at this shutter speed as sometimes the built in one is not enoughbut this all depends on what and where you are shooting.
Matt Stahley is offline   Reply With Quote
Old August 27th, 2002, 02:15 PM   #4
Has anyone really compared frame mode to a post production film-look filter application? I don't think I've ever seen one.
Mike Rehmus
Old August 27th, 2002, 02:33 PM   #5
Drew Craig
Posts: n/a
progessive scan
thanks for response.
i just shot at shutter speed 30 and with good lighting=--- and you're right it turned out looking filmic (w/ some help from after effects). it's the outdoor work that i'm concerned w/--
any suggestions on good filters that will help w/ over exposure at 1/30 AND OR filters that knock out that "video" feel?
drew
(? Black Promist filter, Tiffen ?)
Old August 27th, 2002, 02:49 PM   #6
The Black ProMist does make it look a bit dreamy. But I've got a #1 and I haven't tried it at one-thirtieth of a second. So I cannot evaluate it for the film look for you.
Mike Rehmus
Old August 27th, 2002, 05:39 PM   #7
I can't set my VX2000E to 30 FPS only 25 FPS. Is this something to do with Pal being 24 FPS and NTSC being 29.97 FPS?
Chris Tsamados is offline   Reply With Quote
Old August 27th, 2002, 07:14 PM   #8
It sure does. The shutter speeds are related to the number of interlaced fields. PAL has 50 fields, therefore the shutter speeds will corespond with that.
You are also a little mixed up in your names of things.
FPS is Frames per second. This is the number of frames of interlaced/full frame video recorded in one second. In consumer cameras this is not adjustable.
PAL is actually 25fps, film is 24 and as you mentioned NTSC is 29.97
Adrian Douglas is offline   Reply With Quote
Old August 28th, 2002, 03:17 AM   #9
Opps I meant to say I can't set the shutter speed to 1/30, it was late thats my excuse.
Old August 28th, 2002, 07:46 AM   #10
I realized that Chris. Either way if your camera is a PAL version, which apears to be the case, the available shutter speed will be 1/25 of a sec, for NTSC it will be 1/30
