An outdoor gig shooting with VX2000 and VX2100 at DVinfo.net
Old August 29th, 2004, 01:47 PM   #1
Hello.
I will shoot a gig that that will involve two VX2000s and one VX2100 at the same time. I have a question - do their footage match each other? I mean if i set the exact same f-stop on VX2000 and VX2100, will I get the same picture or the VX21000 will be brighter due to fact that it has more sensitivity? If yes, is the difference very noticeable and how to handle this problem?
The second question is - how would you set up those three cameras to gain most efficient footage? What position of the cameras, etc.
I will appreciate any comments.
Milosz Krzyzaniak is offline   Reply With Quote
Old August 29th, 2004, 01:59 PM   #2
The cameras will be close enough that you should see very little difference.
You should always set up each camera separately to guard against mistakes. Use one camera's settings to adjust the other two but then check the image on each camera.
Answer 2. You don't give us any information about what you will be doing with the cameras, shooting conditions, what you are videotaping, etc. We cannot answer you without that information and more.
Mike Rehmus
Old August 29th, 2004, 02:10 PM   #3
Good point.
So it will be a hip hop event (what could it be else in the early XXI century!). There will be a stage on a sort of playground. The gig will begin after sunset. There will be some people having fun in front of the stage... so, just a gig:)
My producer wants it to look as a videoclip, so there should be a lot of dynamic shoots, including playing/singing band and audience enjoing the gig as well.
I just may add that it's not going to be a very big event, just 200-300 people in the audience.
Old August 29th, 2004, 03:26 PM   #4
One minor difference between the 2100 and 2000 might guide some decisions. The VX-2000 only has 12 click stops for adjusting iris in manual mode and this results in a noticeable bump as you turn the dial. They improved this somewhat on the VX-2100; it has 19 discreet stops (the PD-170 goes even further with 24 stops). So if you're going to be riding the iris in manual mode on one of these cameras, make that the VX-2100 for smoother results.
Old August 31st, 2004, 10:30 PM   #5
The 3 cameras will take pretty identical video so long as you manually white balance them. The auto white balance is often a bit different between the cameras, and will often change a bit depending on the scene. This is the most critical step in getting similar footage from the 3 cameras.
Alan Christensen is offline   Reply With Quote
Old September 6th, 2004, 12:01 AM   #6
Is that right Boyd? The VX2100 has more aperture click stops than the VX2000? Fist time I've seen this written down, so have you actually tested it to find out this information?
tom.
Old September 6th, 2004, 06:51 AM   #7
No, I'm wrong. Thanks for pointing that out. I've been trying to find an answer to this for a little while so I finally posted another thread and got one: http://www.dvinfo.net/conf/showthrea...threadid=31245
The question came up on another forum so somebody there dug around Sony's website and found some misleading information. They stated that the PD-150 and VX-2000 had 12 iris steps, which is correct. But they listed the PD-170 with 24 steps and the VX-2100 with 19 which gave me the wrong impression. In fact, the VX-2100 also has 12 steps; the other 6 clicks are for gain, plus one for closed.
Bottom line is that the iris was only upgraded on the PD-170 and not the VX-2100, which is the same as the VX-2000.
Old September 6th, 2004, 08:06 AM   #8
Glad we cleared that one up. I was wobblin over the fact that it looked as if I'd been giving out duff info for nearly a year.
tom.
