polarizer on pd170
I cannot for the life of me fit a tiffen 58mm polarizer on the front of the PD170 prime lens while keeping the standard sunshade on. Am I doing something wrong; am I just stupid? What's the point of having a polarizing filter on when I have no protection from flares and glare. Please, I'm desparate!
Thanks |
BHPhoto.com should have what you need either individually or in a set. Thats where I got mine a few years ago.
Don B |
Don, do you mean an adapter?
Thanks |
Unless there is something quite different with the polarizer, you should be able to remove the lens shade, install the polarizer and then place the sunshade back on.
That said, the sunshade will get in the way of your manipulation of the polarizer and you may require a round sunshade that screws into the front of the polarizer. I have a PD150 and could be wrong about your 170 because it is possible that Sony has changed the design in that area.
Mike Rehmus Hey, I can see the carrot at the end of the tunnel! |
#5 |
Thanks for the reply Mike. I tried a regular 58mm tiffen round polarizer and the end of the filter is larger than the opening for the sunshade. I tweaked with it for over an hour to no avail. Maybe I'm just stupid, I don't know. I'm thinking about buying the Century optics 4x4 filterholder/sunshade and just bypassing the hole deal.
Thanks for the help though, Michael |
#6 |
Even if you get a polarizer to fit, you still have to operate it. That's why a circular screw-in lens shade in 58 mm may be a good idea. It would have to be for a wide-angle lens i.e., not too deep. Best to try different candidates on-camera and look for vignetting.
The Matte Box is certainly a nice tool if you can afford it and, for most applications, your needs are stationary.
#7 |
Michael,
Your PD-170 comes with another lens shade for the wide angle lens. Use that shade when you want to use your polarizer filter. It's a two-part shade. The front part twists off to allow you to attach the WA lens, and you can do the same to attach your polarizer. With the front part attached, there is room to adjust the polarizer. While I like the convenience of the 170's rubber sunshade with the levered lens cover, I use the WA shade instead because of the ease of attaching the WA adapter and my polarizer. You don't need to buy the Century filterholder, unless you really want to! : ) |
#8 |
Allen,
Thanks for the good advice. I'll give that a go. |
